Results 1 to 20 of 21
Thread: LSX Opinion's!!!!
02-01-2008, 08:39 PM #1
LSX Opinion's!!!!
How much horse power can an all iron LS6 block handle when on boost.(block only)??
02-01-2008, 08:41 PM #2!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
iron ls6?
02-02-2008, 06:53 AM #3
Are you talking about the new Iron LSX block from GM Performance?? If so, those things are rated at 2500hp.....
02-02-2008, 08:28 AM #4
02-02-2008, 08:57 AM #5
I know they are national back order....where are you hearing about the rear cylinder issue? I've only seen a couple and to date I dont know of any issues....will be curious about any problems with this block.....was it something GM came out and said there was an issue with?
02-04-2008, 10:39 AM #6
Im sorry its the LQ9 block. here's a link.
http://www.sdparts.com/product/12572...nderBlock.aspx
its a 6.0 L cast Iron Block
02-04-2008, 05:49 PM #7
im sorry its not an LS6 its like an LS2 but iron.
its called an LQ9. its says it can bolt up LS1 parts.
Cast iron with 6-bolt, cross-bolted main caps the AWD cadilac come' with it.Last edited by yellowlt1ta; 02-04-2008 at 05:58 PM.
02-04-2008, 05:49 PM #8
here's a link
02-04-2008, 07:17 PM #9
Its an iron 6.0 block, same as the Ls1 except for being iron and having a larger bore. I've seen them handle quite a bit of power, north of 700whp.
02-04-2008, 09:04 PM #10
Thats the one. Do you think it can hanle my 1,000HP goal. beacause my LT1 sure didnt. I need to know because it plan to buy a block this week!
02-04-2008, 09:39 PM #11
Are you talking 1,000 flywheel or to the ground b/c they are two totally different ballparks. It might be able to survive flywheel, but if your gonna spend that kind of money, you should probably get an LSX. But I wouldn't get in a hurry on ordering b/c I believe the LSX's are backorder like a mother.
02-04-2008, 09:44 PM #12
Dame its just i messed up my LT1 that I was building up and Im looking for a block that can take it. If the LQ9 cant handle the 1k on the ground (RWHP) then I wont use it. the LSX blocks are back orderd till like next year. lol and they are too expensive. Im looking for a strong block that can take 1K to the ground.
02-04-2008, 09:58 PM #13
Well, if the LSX is too expensive, I don't know what to tell ya. You gotta pay to play and 1,000 to the ground takes a ton of money. There's the LS7 block, but I don't think it can handle that kind of power.
02-05-2008, 10:21 AM #14
everyone says they want 1000HP and 99% of those that say that have not done their homework and have no idea what they are asking for. Sorry if I sound like as ass, I have just seen 500 of these posts scattered across the web. "Hi, I wnat 1K HP and I have a budget!" Even aluminum LS2 blocks can hold that power, the block isn't a limiting factor, but you aren't gonna see it without lifting the heads on ANY factory LS setup outside of the new 6 blocks like the ERL, LSX, etc.
02-05-2008, 10:22 AM #15
I got a budget of about 15k. I know its expensive to get to 1kHP but it seems that 1kHP is about 30k buck's. I got the turbo system to buy as well. Im just trying to keep cost down if I can.
02-05-2008, 10:27 AM #16
My engine builder has told me the samething. Im trying to take it one step at a time. Block first, then Internals then Heads, then the Turbo System. So he tells you whant 1kHP then start off with a Dart block and have 30,000 buck's.
02-05-2008, 11:02 AM #17
Well on an LS setup, block first means consider holding the heads down too, and you aren't likely to hit 1krwhp without a block with 6-bolt heads. 14-15K will get you the long block you need, but you will still need the turbo, piping, and accessories, the mega $$ fuel system, tuning solution, and a drivetrain.
02-05-2008, 11:11 AM #18
I think that if i go LS ill spend more than if I use a diffrent motor. I just got off the phone with my engine builder and he say's to back down on my HP goal and take a look at 700hp b/c he say's 15k is too little for what I want. he say's that if I do go LS I will spend alot more. I dont know were to go right now.
02-05-2008, 12:11 PM #19
700hp is than you probably will be able to use unless this is a drag only car, I have a feeling you'd be plenty happy with 700.
02-05-2008, 08:05 PM #20
A 6.0L iron block will handle 1000rwhp fine and will work as a street/strip car. What internals you use will matter as well. Over 1200 I would look at the LSX or warhawk block.
Need Your opinion
By Adam_94_T/A in forum Almost Anything GoesReplies: 15Last Post: 03-07-2011, 01:52 PM -
Need an opinion
By JML6820 in forum Firebird / WS6Replies: 5Last Post: 09-25-2010, 01:22 PM -
Question: What is your opinion?
By Oldgoatherder in forum Firebird / WS6Replies: 12Last Post: 07-16-2009, 09:57 AM -
Want to buy this 98 Z28 but. need opinion
By voodoochi1d in forum General HelpReplies: 9Last Post: 08-24-2007, 08:27 PM -
Opinion on 01 Z28
By jshilli1 in forum Camaro / SSReplies: 7Last Post: 04-02-2007, 09:02 AM
