Results 1 to 14 of 14
    Jan 2008
    ottawa
    1998 pontiac transam ws6
    ....skip-shift...
    anyone try the skip shift Eliminator ? i was wondering if anyone could leave some feedback or something they have done..i really hate the 1st to 4th thing.. thanks
    Member Z27's Avatar
    Northern KY
    Green Red Black
    71 SS 00 SS 06 Impy SS
    Probably everyone on here with an M6 has one except you. It is definitely a must have. There are a couple of ways to do it, either get a premade one or go the built you own method. The premade ones just plug in and wire tie out of the way. Not very expensive and seal everything up to keep out the elements. I brought my SS home from the dealer and jacked it up to install the skip shift plug. Just couldn't see the 1-4 thing.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It can be turned off in the PCM as well.
    Jan 2008
    ottawa
    thanks guys i think im going to get one , apreciate your help. thanks
    NC
    I have the SLP one and it works great. The light on the dash still comes on though....
    Junior Member cdorch's Avatar
    Cape Cod
    1998 Z28 M6
    yea with all the eliminators ive seen the light still comes on but regardless of what the light says, 4th gear is no longer your only option
    maine
    2002 z-28
    i have the SLP one as well...light still comes on......works flawless. cheap mod
    Member AiDRocks's Avatar
    Bay Area, Cali
    1999 WS6
    Cheap easy mod to do!
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    This is a must do mod. Dealers should just throw them in as a courtesy.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    I haven't had any issues with it. It took a little while to learn when it came on, but I know how to avoid it, or use it if it's appropriate.
    If your WOT doesn't matter that it's there.
    If you're in slow traffice or making a slow turn, just keep it in 1st a little longer. It will turn off between 3,000 and 3,500 rpm.
    Member jd2002ss's Avatar
    Clinton Twp. , Mich.
    2002 ss Convertible
    This was my very first mod!!! That 1st to 4th thing sucked
    WI
    Blog Entries
    1
    3500 rpm's in the work parking lots is not good for me. I get nasty looks when the cold pipes crack at 2500!
    Arizona
    Quote Originally Posted by Hot Black Trans-Am View Post
    Why would you go that fast in a parking lot anyway??? Dirty looks with pipes crackling,,,,lol,,,I would think people are used to that by now with all the kids and their fart pipes running around,,,lol.
    There are a couple of tricks to get around skip shift. Like mentioned once you are over 3,000 rpms it shuts off.
    Also you can double clutch the car and shift anywhere you want. Roll out in first, shift anywhere under 3,000 rpm that you like, pull the shifter into the neutral gate let clutch out, push clutch back in and it will pull right into second gear no problem. Just a simple way to fool the computer.
    Although this worked for me my wife couldn't deal with it so ya,,,,,I had to install a skip shift eliminator eventually. I used SLP's, works fine, I hear no more complaints about it.
    Feb 2008
    Clarksville TN
    Blaco
    2000 Pontiac Trans Am
    i just boughts a trans am. where is this skip shift plug located so I can turn this thing off?
  1. Skip shift
    By johnfin in forum Firebird / WS6
    Last Post: 07-28-2012, 10:48 AM
  2. Skip Shift
    By 10erg01 in forum Manual Transmission
    Last Post: 12-11-2010, 10:22 PM
  3. Question: skip shift
    By 99yellowz28 in forum Manual Transmission
    Last Post: 09-07-2010, 06:44 PM
  4. 1-4 skip shift
    By 1stgto in forum GTO
    Last Post: 03-18-2010, 08:54 PM
  5. Skip shift!!!!!!! YUK
    By Christibelle in forum Firebird / WS6
    Last Post: 03-01-2007, 04:44 PM
