Thread: Why all the sudden
01-27-2008, 11:39 AM #1Junior Member
- Oct 2007
- Middletown,Ohio
Black- 1999 Z28
Why all the sudden
So I have Owned My 99 M6 Z28 since september 2007. Its got a 9" rear end and some after market control arms (not sure what brand but they are not adjustable) anyways I have never had any trouble with wheel hop but now all of the sudden this thing wants to beat it self to death if do a burnout. I bottomed it once and hit the sub frame connector pretty hard a while back and the day I first noticed the wheel hop I had put some air in the tires before I left in the morning.
Any Idea's on what is causing this. I was thinking maybe I killed the shocks or bent something when I bottomed it out but I dont know a whole lot about wheel hop or what causes it. Any Advice is very appreciated.
Thanks
01-28-2008, 06:22 AM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
sounds like some new shocks are in order.
01-28-2008, 07:20 AM #3Senior Member
- Aug 2001
- San Diego, CA
383 w/Meth & ProCharger- 2001 Camaro Z28
You should put it up on stands and check everything. Make sure nuts and bolts are tight....all that stuff. Take some measurements of the rearend alignment and make sure it's square. Also check your pinion angle, if you have an adjustable torque arm make sure the adjuster nuts are tight too. Nothing would just change on it's own for no reason.
01-30-2008, 08:20 AM #4Junior Member
- Oct 2007
- Middletown,Ohio
Black- 1999 Z28
Thanks for the input guys.
Ill get it up on a lift and check her out.
Some new shocks are on the way for good measure.
01-31-2008, 01:10 PM #5
Help: Sudden misfire..
By Smittro in forum General HelpReplies: 55Last Post: 05-27-2010, 07:28 PM -
Sudden Revving
By 02C5Rocket in forum General HelpReplies: 10Last Post: 07-02-2009, 01:02 PM -
serious engine studdering all of a sudden
By jmatt07 in forum General HelpReplies: 23Last Post: 06-25-2009, 05:50 AM -
All of the sudden...
By MikeSomething in forum External EngineReplies: 14Last Post: 08-09-2007, 12:32 PM -
HSW Sudden Impact
By MavrickCJH in forum Parts ReviewReplies: 0Last Post: 01-11-2007, 12:21 PM
