Thread: General M6 Questions
12-02-2005, 06:36 AM #1Member
- Oct 2005
- Northglenn, Colorado
Black/Gold....Now Sold...- 10th Anny. Firehawk #001
OK, I'm probably the least technical person on this board, but here goes.
I've seen past threads and experienced myself issues with particular shift points on the M6 tranny. For instance, some have a hard time getting the car into reverse, or they complain about hitting the 2-3 shift, etc.
Can the shift forks, syncros, etc. be adjusted in any way to reduce or eliminate these types of problems? If so, where would someone get this type of work done, a regular tranny shop, performance shop, or....????
12-02-2005, 07:04 AM #2Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
A new master cylinder on the earlier cars 98-00 will help alot for going into gear. Some of these cars the clutch doesn't fully engage. As far as missing gears the 3/4 shift fork is aluminum and will bend. They have a replacement for this it is steel. No way to adjust the synchros.
12-05-2005, 04:59 AM #3Member
- metro Detroit area
The T56 has a single-rail linkage design that does not go out of adjustment so it does not need adjusting like old external linkages of the past.
12-05-2005, 07:49 AM #4Junior Member
- somewhere
Black- A car
Occasionaly I'll have trouble shifting into first. Owner's manual makes not of it though. Just have to release the clutch and try again. The same may go for reverse.
I think the 2-3 shift may be a combination of 2 things. First, the stock tranny mount allows the tranny to shift to the side slightly during shifting, moving the 3rd gear shift point slightly. Second, the rubber isolator on the stock shifter cuts down vibrations, but allows the stick a bit too much freedom of movement independent of the shift linkage. Together it makes it harder to hit that 3rd gear.
General Info to some common questions
By Redphoenix1998 in forum Firebird / WS6Replies: 128Last Post: 07-03-2013, 09:50 AM -
Help: general upgrade questions
By DDuarte in forum Camaro / SSReplies: 4Last Post: 09-22-2010, 08:57 AM -
general questions about a procharger
By bpopham22 in forum Forced InductionReplies: 113Last Post: 08-03-2010, 08:35 PM -
A few general questions?
By Tampa T/A in forum General HelpReplies: 4Last Post: 04-23-2010, 08:41 AM -
Picked up a 2001 Trans Am...general questions
By cascade in forum Firebird / WS6Replies: 34Last Post: 05-04-2008, 01:56 PM
