Thread: Computer (ECU?) swap
01-26-2008, 09:37 AM #1Member
- Nov 2006
- New Jersey
Sunset Orange Metallic-M6- 2002 Pontiac Trans Am WS6
can a dyno tuned computer (ECU?) from a 2002 WS6 auto be swapped into a 2002 WS6 6spd successfuly without any problems? thanks
01-26-2008, 09:55 AM #2
The OS's are different, though I suppose fuel and timing tables could be copied over into a new file, but if it's cammed, idle needs will change and require retuning. You'd want tuning for that tranny too rather than OEM tables.
01-26-2008, 10:02 AM #3Member
- Nov 2006
- New Jersey
the first car had long tubes, underdrive pulley, 160 thermostat, slp intake, and high flow cats. nothing crazy like heads or cam
the second car is stock at the moment.
01-26-2008, 10:09 AM #4
Why would you want to move the tune to a different setup with different needs?
01-26-2008, 10:10 AM #5Member
- Nov 2006
- New Jersey
the first car got wrecked, im getting the new computer if the swap can work
01-26-2008, 10:14 AM #6
No it won't go in there and work without further tuning in the PCM. Even if would, the setups still aren't the same, so fuel and spark requirements would be different.
01-26-2008, 10:14 AM #7Member
- Nov 2006
- New Jersey
ok thanks
Question: truck computer versus car computer
By BBCCarguy in forum Computer & TuningReplies: 1Last Post: 11-03-2011, 08:47 AM -
Dyno Tuned Computer (EDU?) swap
By tav8ws6 in forum General HelpReplies: 0Last Post: 01-25-2008, 09:11 PM -
computer wizards - any way to watch videos which are on my computer on my tv?
By SLIM_DURST in forum Almost Anything GoesReplies: 10Last Post: 10-29-2007, 03:50 AM -
Engine swap and computer swap
By mrmiatanut in forum Computer & TuningReplies: 4Last Post: 09-08-2007, 05:10 PM
