    retired racer not 4 long chevy1966's Avatar
    mississippi
    red white
    1999 z28 vert 1998 z28 ht
    I am just full of questions
    Another question for you. I am beginning to perform a new combo for my car.
    It already has a tb bypass, p&p tb, 3200 convertor, magnaflow catback, lid, k&n filter, free ram air, 160 t stat, & custom tune for these mods. I am adding a cam, 228/230 581/588 w/114 lsa, long tube headers, custom y pipe no convertor, ls6 intake, ls6 port/shimmed oil pump, Zeks 175 wet kit, and most likely a set of aftermarket heads, TFS or AFR. Now for the questions, with these new mods will I need some kind of a fuel system upgrade, ie injectors, boost a pump, blah, blah, blah? 2nd question, what do you guys think of the TFS heads? I already know I have to run aftermarket roller tipped rockers & .100 longer pushrods with these. I am shooting for the mid tens, do I have enough AMMO? BTW this is my convertible we are talking about!
    Member 2-bowties&abird's Avatar
    Jan 2008
    lancaster,va.
    cam/lt headers
    blue 2000 ws6 m6
    Quote Originally Posted by chevy1966 View Post
    It already has a tb bypass, p&p tb, 3200 convertor, magnaflow catback, lid, k&n filter, free ram air, 160 t stat, & custom tune for these mods. I am adding a cam, 228/260 581/588 w/114 lsa, long tube headers, custom y pipe no convertor, ls6 intake, ls6 port/shimmed oil pump, Zeks 175 wet kit, and most likely a set of aftermarket heads, TFS or AFR. Now for the questions, with these new mods will I need some kind of a fuel system upgrade, ie injectors, boost a pump, blah, blah, blah? 2nd question, what do you guys think of the TFS heads? I already know I have to run aftermarket roller tipped rockers & .100 longer pushrods with these. I am shooting for the mid tens, do I have enough AMMO? BTW this is my convertible we are talking about!
    was the duration on that cam a typo or is it really 228/260?
    mississippi
    red white
    Quote Originally Posted by 2-bowties&abird View Post
    Typo, 228/230, 581/588, w 114 lsa. Thanks
    Jan 2008
    lancaster,va.
    cam/lt headers
    blue 2000 ws6 m6
    i have very close to the same cam it sounds sweet and makes good power very noticeable i would say above 3000 rpm's
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    With a good 60' time, you will run low 11s without your juice with H/C/I combo you are thinking about. Get the most 4l60e that money can buy, you will HAVE to have it on the jug. A 175 shot, if rated at the wheel (not sure what kit you are talking about) will put you in high 9 to low 10 second territory with a good 60'.
  1. Replies: 6
    Last Post: 12-30-2011, 12:40 PM
  2. Full Throttle and A/C
    By aerojt in forum Camaro / SS
    Last Post: 08-27-2008, 04:22 PM
  3. brand new and im full of questions!
    By bad boy 99 in forum Firebird / WS6
    Last Post: 09-04-2007, 07:24 PM
  4. full time AC???
    By First Spray777 in forum General Help
    Last Post: 12-24-2006, 06:21 AM
