Thread: how much fluid to buy
01-24-2008, 09:00 AM #1Junior Member
- Jun 2006
- Baltimore, MD.
Red- 01 Camaro SS
I'm changing all fluid to royal purple, and was wondering how much fluid does the tranny and rear hold?
01-24-2008, 09:03 AM #2
Do you have an auto or manual?
Auto= 14-16 quarts no sure on the manual probably around 3-4 quarts
and the rear diff will take about 2-3 quarts. It does get pricy in the end...hope this helps ya
01-24-2008, 02:35 PM #3Junior Member
- Jun 2006
- Baltimore, MD.
Red- 01 Camaro SS
thanks
01-24-2008, 02:54 PM #4
should say in the last few pages of the owner's manual of the car
01-24-2008, 03:03 PM #5
^^Of course! ^^
The most often over-looked info book that comes with every car....a manual. Yup all the exact fluid types/specifications and amounts are in the owners manual.
Got passenger window problems?
http://www.autotrix.net
**Window Express Down Modules now availible**
http://www.autotrix.net/products.html
01-24-2008, 03:07 PM #6
I've been needing to change the rear dif fluid, but have been to puss to go for it yet. Does anyone know of a write up for it?
01-24-2008, 03:14 PM #7
Not really much to it.
Pull the cover, drain fluid, replace gasket ( or silicone ), pull out fill plug ( usually 3/8 square ) and fill until you can feel the fluid level with your finger inside the fill hole.
You could also try to suck the fluid out and not bother with the cover at all!
01-24-2008, 03:16 PM #8
01-24-2008, 03:20 PM #9
Yeah the hardest part of the job is breaking the seal and not getting fluid everywhere once you have all of the screws out. A neoprene dead-blow hammer works well.
Fluid changes...
By third_shift|studios in forum General HelpReplies: 25Last Post: 08-13-2008, 06:17 PM -
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
How much fluid?
By blk_jaws in forum DrivetrainReplies: 1Last Post: 09-16-2006, 10:52 PM -
What fluid?
By lrader99 in forum Manual TransmissionReplies: 6Last Post: 08-17-2006, 05:14 PM -
Fluid Changes
By CKramer in forum DrivetrainReplies: 1Last Post: 04-10-2006, 05:16 PM
