Page 1 of 4 1234 LastLast
Results 1 to 20 of 65
    I Like It Stroked 99Ls1fever's Avatar
    Greeley,Co
    Artic White
    1999 Z28 408 Stroker M6
    Does NOS Raise Your Compression
    K, well here is my question, I have a buddy that works for a hot rod speed shop, and I have another buddy who is a huge car enthusiast. The guy who works for the speed shop says that Nitrous raises your compression? If so how much does NOS raise your compression on a 11.1 compression vehicle. The car enthusiast says NOS is a chemical break down and does not raise your compression. The are both good friends and I didn't want to argue so I post the question to you. Does NOS raise your compression...? thanks for your time,
    Matt
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    No, it raises cylinder pressure, but compression (static compression) is the result of the ratio of volume between BDC and TDC for a moving piston.
    Member transam98's Avatar
    Herrin, IL
    2003 Ram 2500
    I kinda want to know this two. I would think both your friends are right in one way or another.
    Sweet thanks for the info Frost.
    Greeley,Co
    Artic White
    so just making sure it will not raise my 11.1 compression when i spray...?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by 99Ls1fever View Post
    Not unless it changes your piston's face, bore, or combustion chamber volume at the same time
    SCR is a fixed number based on what I posted above. It *WILL* change your cylinder pressure though.
    Better pull some timing with that kinda CR; good gas wouldn't hurt either.
    Greeley,Co
    Artic White
    in Colorado we only have 91 octane pump gas... this is why i was curious. but isn't cylinder pressure, compression?
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    As I understand it basically cylinder pressure is how much pressure is placed on the cylinder walls from the explosion. Comp ratio is how much the material in the cylinder is compressed before the explosion.
    Greeley,Co
    Artic White
    Quote Originally Posted by Bottesini View Post
    yea that does sound correct to me too. But i just dont want to blow up a $8k dollar engine either... So i am just being safe... But I will be fine then and the compression will be the same, and the only worry is the cylinder wall strength...? correct?
    Greeley,Co
    Artic White
    but wouldn't more material (nos and gas) mean more to combust?
    Blue
    2002 Z28 Camaro M6
    It is still the same size of volume that you are compressing, though the density of what you are compressing changes, since there is essentially more fuel, but the size of the combustion area is still X.
    Greeley,Co
    Artic White
    thats awesome man, so i can spray and not have to worry about my compression going up and it will be safe on the motor....?
    Blue
    2002 Z28 Camaro M6
    Well your compression ratio will not change. As for safe I am not sure. That depends on a few other things. Partially I don't know how you are set up or tuned, and I am sure there are much better experts out there on NOS then me. Personally I would think if you get all the stuff you need, including a tune etc and you have a nice strong bottom end then you should be fine.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    The only thing determining what you can spray is the tuning on your car (to an extent). Need good AFR on the jug and solid timing that yields no knock
    Glen Carbon, IL
    NOS is a namebrand or ricer terminology. N2O is the correct abbreviation for Nitrous Oxide. N2O iscreases the amount of O2 in the cylinder raising the fuel requirements. When you use N2O you need to add more fuel and reduce timing.
    Greeley,Co
    Artic White
    Quote Originally Posted by 02blkws6 View Post
    ok well i call it nos so get over it....
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i run 11.3:1 SCR and a 250 shot on my 408. nitrous likes compression.
    Greeley,Co
    Artic White
    tight man thanks, what octane gas do you run?
    Greeley,Co
    Artic White
    Do you think running 91 octane gas would be fine for running NOS?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Sure.... for sparaying 200 or more, you will want a standalone fuel system, and most put good gas in there, since it takes so little. Though at 150-175 with tuning there is no issue on pump gas. Prolly not at higher levels either, just nice to have that extra insurance
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes it ONLY adds cylinder pressure. By adding a vast amount of cylinder pressure the cylinder thinks it has high compression due to the add. But it doesn't change the motors compression.
    A lot of it depends on the camshaft also. Cams that have big overlap tend to bleed off alot of cylinder pressure at low rpm. That is how alot of people trick the motor by having alot of over lap bleeding off that pressure you can get away with running pump gas on a high compression motor.
    How much bottle do you plan on spraying? Also it says your stroked in your info so what cam,head gaskets, and pistons are you running.
    91 COULD be OK there are many variables that we can't take into fact with your general type ?.
    Also what plug are you running with what gap?
  1. Question: Need to raise back end
    By davidz28 in forum Suspension and Handling
    Last Post: 12-01-2011, 02:29 PM
  2. For those who raise boys
    By Sarge in forum Almost Anything Goes
    Last Post: 03-18-2009, 01:45 PM
  3. Pay too much and you could raise the alarm
    By CaptainCaveMan in forum Political / Debate Forum
    Last Post: 06-05-2007, 11:48 PM
  4. I just got a raise!!
    Last Post: 04-28-2007, 09:39 AM
