Thread: plastic fuel line removal
01-23-2008, 02:34 PM #1Junior Member
- Aug 2007
- sac town
PEWTER- 2001 camaro
I gotta get some warranty work done on my camaro so i need to take the nitrous off so that it dosent void it. When i put the nitrous on i just cut the plastic line and put a T fitting on it. So now i need to buy a new plastic fuel line
from a salvage line and replace it but I have not the slightest idea on how to get the old line off or put it on any help would be awesome.
01-23-2008, 08:24 PM #2
I'm not completely sure which line you're talking about. The only line I can think of is the one that comes up and connects to the fuel rail but it's rubber and not plastic. It has a quick connect on one end but I don't remember what's on the other end. Why not just cap the T connector? If they ask tell them you hooked up a fuel pressure gauge or something and didn't know about the shrader valve.
01-24-2008, 08:09 PM #3
When u instailed your spray, im assuming you put in a wet kit, you should have just removed the Sch. valve and put your line on after the fuel rail. Where you check your fuel pressure. Where exactly did you cut?
01-25-2008, 05:34 AM #4
Little plstic tool you push into the connector to free the lock. Go to auto zone, pep boys, oreily's etc and as for a fuel line removal set maybe 8 bucks max. Just press it into the connector and pull the line off.
kinked fuel line while changing fuel filter
By krese in forum Firebird / WS6Replies: 4Last Post: 10-04-2010, 03:02 PM -
2000 T/A Front Seat Plastic Back Removal
By Tman in forum Showcar and DetailingReplies: 2Last Post: 09-03-2009, 07:04 AM -
By Tman in forum General HelpReplies: 0Last Post: 08-12-2009, 09:35 AM -
Fuel line removal tool?
By surgitech74 in forum General HelpReplies: 1Last Post: 04-21-2008, 04:27 PM -
Removing fuel supply line from fuel rail
By GatorSS in forum General HelpReplies: 8Last Post: 01-02-2007, 05:10 PM
