Thread: cluth pedal on floor after spray
01-22-2008, 11:54 AM #1
- Jun 2006
- Baltimore, MD.
Red- 01 Camaro SS
I have an 01 ss with a wet 100 shot. When i went to the track, at the end of the quarter mile, my clutch pedal was laying on the floor. I stuck my foot under the pedal and lifted it up and then it seemed to be fine. If i just spray3rd and 4th playing on the road its fine. I have a spec stage 2 clutch in it rated for 500hp. Any direction in the right way is greatly appreciated. Thanks
01-22-2008, 12:34 PM #2
need to upgrade your master and slave cylinders. even though you have an '01 you still need to do this. also look into doing the drilll mod to allow more fluid to flow through the lines. also recommend using DOT 4 brake fluid since it has a higher boiling point than the DOT 3 youre using now...
01-22-2008, 12:45 PM #3
- Jun 2006
- Baltimore, MD.
Red- 01 Camaro SS
where can i find out about this drill mod?
01-22-2008, 12:57 PM #4
01-22-2008, 02:20 PM #5
- Jun 2006
- Baltimore, MD.
Red- 01 Camaro SS
thanks
cluth pedal sensor error??
By JDCAMARO99 in forum Manual TransmissionReplies: 4Last Post: 08-24-2010, 03:00 PM -
Clutch pedal to floor
By Colduck in forum Manual TransmissionReplies: 1Last Post: 07-11-2008, 09:31 AM -
pedal 2 floor
By petercar06 in forum Manual TransmissionReplies: 8Last Post: 04-28-2008, 11:07 AM -
clutch pedal going 2 floor
By petercar06 in forum New Member IntroductionsReplies: 1Last Post: 04-27-2008, 07:50 PM -
Clutch pedal stays on the floor
By Vinco in forum Manual TransmissionReplies: 13Last Post: 02-11-2007, 01:17 PM
