    It ain't Rocket Surgery ! BowTieBob's Avatar
    Delaware
    Pewter/Black
    2K Z28/05 Avalanche
    Headlight covers
    Has anyone had any success in removing haze from their headlight covers?
    If so, what product did you use and what method?
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    Headlight Haze
    I had that problem on my 00 SS and I used a product here from work at Year One called Plastic Polish. The part #pk45. THe kit cost 43.95 and it worked great. It comes with everything to polish and clean up those headlights. It worked great on mine. It comes with instructions on how to use it.
    Delaware
    Pewter/Black
    2K Z28/05 Avalanche
    Thanks. I'll give that a try.
    houston
    PEWTER
    2001 Z28
    I had good luck with wet sanding using 1500, then 2000, then 2500 grit, then using blue magic plastic polish and blue magic metal polish.
    steveo346
    Guest
    i went with the wet sanding method as well, i started with 800 grit then 1000 grit and finished off with 1500grit and some of my home made polish.
  1. Question: Headlight Covers
    By ArcticZ in forum Appearance Section
    Last Post: 04-04-2011, 10:53 AM
  2. Headlight covers
    By mikmar in forum Firebird / WS6
    Last Post: 07-11-2007, 01:59 PM
  3. headlight covers ...
    By snaggeltooth in forum Camaro / SS
    Last Post: 07-29-2006, 02:35 PM
  4. Headlight covers...
    By cool87gn in forum Appearance Section
    Last Post: 04-24-2006, 09:50 AM
  5. Uneven Headlight covers
    By Waynestep in forum Firebird / WS6
    Last Post: 04-19-2006, 12:18 PM
