Results 1 to 20 of 23
Thread: How to bench more weights?
01-20-2008, 06:07 PM #1
I am 6'3 185lbs and I bench 135lbs 4 x 7-8 and thats it. My upperbody is not that strong however i can challenge huge guys on leg exercise.
I need tobe able to bench at least 185lbs in 2 weeks. (ONLY FOR 1 TIME, JUST BRING IT DOWN TO MY CHEST AND PUSH IT UP) how can I improve this?
thanks!
01-20-2008, 06:16 PM #2
What do you need to bench your body weight for?
01-20-2008, 06:19 PM #3
01-20-2008, 06:19 PM #4
01-20-2008, 06:21 PM #5
practice on heavy reps, do a set of 135, then 145 then 155 then 165, each time doing less reps, also work out your supporting muscles for benching (triceps and shoulders), im 6'2, 160 and max 225
01-20-2008, 06:22 PM #6
Have you tried your max to see what it is?
01-20-2008, 06:30 PM #7
damn you guys are some skinny tall folks...
im 5'11 and the most i put up was 265 when i weighed 176... it took me a long time to get up there though...
first like the other guy said you need to find your max right now... ill save you the trouble and say its at 165 give or take.. 20 pounds can be done in two weeks but its really hard... eat a ton of carbs and protein every day and work your chest 3 days a week doing supporting muscles in between and taking one day off.. do flat bench, incline, decline, and flies, starting out with a warm up weight that you can get 10 at rather easily and then dropping down to 6 reps, 5 and 4. should do the trick and just remeber to get really pumped and get the adrenaline flowing on the day because that will make all the difference
01-20-2008, 06:30 PM #8
the best way to do this is to add 10 lbs to the 135 and go for as many as you can with that. THen when you can add more, add more. The goal you are looking for is gonna be hard. Its really hard to add 50 lbs to your bench in only 2 weeks. you might be a day late and a dollar short on this. But my guess is you arent really pushing yourself trying to lift heavier.
01-20-2008, 06:31 PM #9
01-20-2008, 06:33 PM #10
01-20-2008, 06:35 PM #11
maybe not incline, but defintely decline... if his ONLY goal is to get to 180 then he can cut that out, but i noticed when i was getting to 265 on flat my incline jumped a lot too as i was repping 185 6 times... your body functions as one piece and its a lot easier to get stronger if you focus on supporting muscles..
good luck though man sounds tough
01-20-2008, 06:36 PM #12
01-20-2008, 06:36 PM #13
do lots of dips, thats helped me out as it gives your chest a nice stretch and it builds your tri's up.
01-20-2008, 06:37 PM #14
01-20-2008, 06:52 PM #15
cool thanks guys.
01-20-2008, 07:01 PM #16
chest 3 days a week?!!?!?! i wouldnt recomend that, at most 2, concentrate on your triceps and shoulders along with your chest
01-20-2008, 08:02 PM #17
+1 for dips too.
01-20-2008, 09:08 PM #18
just put the 185 on there, and tape a knife to the bottom of the bar, so that way, you either lift the shit up, or you get fucked up. that'll do the trick.....worked for me..
01-20-2008, 09:11 PM #19
ya ur clearly OUTTA UR FUCKING MIND hahaha
01-20-2008, 09:16 PM #20I keel you!
- Titus,AL
Black as Wesley Snipes- 09 Mazda 3, 12 Z1000
I will tell you a GREAT way to increase your upper body lifting is by strenghtening your grip... Thats all I can add that hasn't already been said
Wheel weights
By 024mula in forum Wheels and TiresReplies: 6Last Post: 03-12-2013, 04:00 PM -
Wheel weights!!
By blackSS01 in forum Wheels and TiresReplies: 5Last Post: 05-25-2011, 04:02 PM -
Hood weights?
By MistrCreazil in forum Firebird / WS6Replies: 3Last Post: 11-14-2009, 07:38 PM -
Mixed oil weights.
By seratt in forum General HelpReplies: 6Last Post: 08-29-2008, 02:36 PM -
Question: Wheel Weights
By Selah in forum Wheels and TiresReplies: 7Last Post: 04-13-2008, 09:38 AM
