    Jan 2008
    Conway, SC
    2000 Pontiac Trans Am
    TCS Control Module
    I am interested in buying a SLP traction control module. I was wondering what the benefits from street use would be. In the SLP product description it just talks about track use. Also does any one know where this would plug in and mount in my car (2000 Trans Am)
    Junior Member kikaofazz's Avatar
    Fayetteville, AR
    2002 Pontiac CETA M6
    I just installed one of these, myself. All you have to do is pull the TCS trim out of the console, unplug the TCS switch from the trim, then plug the harness into the switch. Thats it! It took me all of 90 seconds. I don't think it's necessary to mount the logic module, since it's hidden in the console.
    The only thing it does is reverse your tcs switch so it defaults to off.
    Senior Member
    Jacksonville, FL
    Yep. Buddy of mine had to back up at the track and shut the car off so they could clear it. When he restarted the car ASR was on and forgot to turn it off before his run...
    Norfolk, VA
    Spice Red
    2006 GTO A4
    Quote Originally Posted by kikaofazz View Post
    I am having a little trouble installing this in my 2006 GTO. Did you have to run a power wire to the fuses? If so, did you use the accesory fuse? For some reason, mine is not working and I am just wondering if I am doing something wrong.
    Fayetteville, AR
    Quote Originally Posted by 1badls1m6 View Post
    I'm not sure about the TCS switch in GTOs. For f-bods it's literally a plug-and-play design. No wires to run. Surely there are some more GTO owners that can help you out! I couldn't imagine the design being that different, but who knows with GM these days...
    Norfolk, VA
    Spice Red
    2006 GTO A4
    I tried plugging it in without connecting a power source to it and it works. I don't know why it advises to connect it to the fuse box. Thanks for the tip!
    Fayetteville, AR
    Glad to hear it worked out!
  1. Cruise control module
    By az gt eater in forum Appearance Section
    Last Post: 05-25-2011, 05:34 PM
  2. body control module
    By black transam1218 in forum Stereo and Electronics
    Last Post: 08-09-2009, 12:10 PM
  3. cruise control module
    By 1MileCrash in forum General Help
    Last Post: 04-21-2009, 10:55 AM
  4. Powertrain Control Module(HELP)
    By Adam_christensen@msn in forum Stereo and Electronics
    Last Post: 07-22-2008, 09:56 AM
  5. 95 vs 96 Ignition control module
    By RapidoBandido in forum General Help
    Last Post: 08-15-2006, 08:44 PM
