Thread: SFC Install Problem
01-19-2008, 08:05 AM #1Junior Member
- NC
Black- 2001 Camaro SS
SFC Install Problem
I recently got the 3 Point SLP bolt on SFC's and I have a few problems installing them. The first is that I have some damage to the underside of the car and the front subframe of the car where the SFC mounts to on the driver's side is dented up about 2-3 in. I tried to bend it down with some tools, but had no luck. Any ideas on how I could fix this?
Also, the bolt-ons come with metal bars with the threaded bolt holes drilled in that you slide up into the subframe and then thread the bolt into them. Because they have to be up in the subframe, how do you keep the smaller bar from spinning around while you try to screw the bolt in. I tried putting a tool up next to it to hold it in place, but had no luck. This is only a problem for the smaller bar with one hole. The other one for the front is larger and won't spin.
Any ideas/help would be appreciated....
01-20-2008, 10:07 AM #2
If your front subframe was damaged that badly, you might consider taking your car to a body shop that has a frame rack to see if there's other additional hidden damage. No sense in putting on SFC's if your car isn't set up properly and untwisted. SFCs should basically bolt right in without any major problems or frame mods.
01-21-2008, 08:28 AM #3Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
I have these SFC's, but you well want to get the car fixed and untwisted before installing the connectors. I had no problems installing mine, I did us a lift and had a extra person to help hold things.
As for the bars make sure the bars are treaded okay. I helped a friend out with his set and the one hole just needed to be retapped. He could not get the bolt to screw in, the screw would stick and the bar would spin.1998 Camaro SS Hard Coupe Bright Red #1593
Mods: Lots!!, still my daily driver except for winter
383rwhp 370rwft/lbs
1979 Corvette
Mods Lots!!, weekend cruiser
325rwhp and 320rwft/lbs
2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
Mods: Catback, BFI CAI, Winter daily driver
01-22-2008, 08:24 AM #4Junior Member
- NC
Thanks guys. I think you are right about rethreading the hole for the bolt. It doesn't seem to go in very freely and binds. The subframe damage is only in that one place where part of it hangs lower than the rest. Looks like I will have to get a body shop look at it sometime soon. Might as well just pay them to install or weld on the SFC's while I'm at it I guess.
01-26-2008, 07:34 PM #5Member
- Jul 2006
- Glen Carbon, IL
Silver- 2000 Camaro SS
Weld them in! Problem solved.
Problem after cam install
By blownh2x in forum Internal EngineReplies: 8Last Post: 03-28-2010, 04:06 PM -
Help: Problem with my install
By Ws6islife in forum External EngineReplies: 5Last Post: 03-27-2010, 01:38 PM -
big problem with cam install
By via sin dios in forum Internal EngineReplies: 14Last Post: 11-10-2007, 02:27 PM -
problem after header install
By phantazn in forum External EngineReplies: 7Last Post: 11-06-2007, 04:53 PM -
Problem with new clutch install, need help
By FuriousGeorge in forum Manual TransmissionReplies: 0Last Post: 04-27-2006, 06:17 AM
