Results 1 to 10 of 10
Thread: Tranny problems
01-15-2008, 06:59 PM #1
Tranny problems
Dnt know wat it is but alot of times wen i cum to a complete stop it does'nt wana get any gears,(it locks me out) but once it finnaly does all of them are fine. they dnt grind the clutch seems fine it dnt slip. any suggestions on wat it could be????
01-16-2008, 03:14 AM #2
synchro's? thats my guess...
01-16-2008, 07:08 AM #3Junior Member
- Dec 2007
- South Carolina
Red- 2002 Transam WS6
You might want to go get that checked out. I had something similiar happening to mine, but I didn't take it anywhere. Needless to say, yesterday I just got my car back with a completely rebuilt transmission. Alot of money, not too happy about it.
01-16-2008, 10:19 AM #4Junior Member
- Oct 2005
- Georgia
pewter- 2000 trans am
synchros
01-16-2008, 11:08 AM #5Mr. P
- Jul 2007
- Augusta, Georgia
Bright Red- 99 Z28 M6, 03 Gixxer 1000
Not to jump the thread, but how are the syncros checked? Mine does this but very rarely.
Thanks
01-16-2008, 12:01 PM #6
x2 on the sychros (or your clutch isn't fully disengaging).
Sychros can't be physically checked w/o opening the tranny. But, you can "test" them by rowing thru the gears when stopped. Also, if you have trouble shifting while driving or grinding when shifting, you are probably looking at a synchro issue.
01-21-2008, 09:04 PM #7
Dont think its the synchros cuz none of the gears grind and i dnt have trouble shifting wen driving, even wen shifting hard at high rpm's. The only problem is sometimes wen i cum to a complete stop.
01-22-2008, 09:13 AM #8
It's possible that it's just the way the gears in the tranny line up sometimes when you stop. I know Mustangs (T5 tranny) are notorious for having to go into a forward gear (like 5th) before going into reverse...Part of that is b/c reverse is not synchro'd, but it also just depends on where the tranny stops.
I'm still learning about F-body manual tranny's b/c they use a hydraulic clutch, so I may be off on this: I might check and see if the master or slave cylinder need to be replaced.
01-22-2008, 03:49 PM #9
Thanks ima check that. Is it something i can do my self???? where is it at??
01-23-2008, 05:22 AM #10
Tranny problems?
By GottaHaveLS1 in forum Manual TransmissionReplies: 0Last Post: 04-07-2006, 09:01 AM -
tranny problems???
By 94formulaLT1 in forum Automatic TransmissionReplies: 4Last Post: 03-17-2006, 06:52 PM -
Tranny Problems
By Sam SS in forum Manual TransmissionReplies: 4Last Post: 12-06-2005, 05:05 AM
