Results 1 to 17 of 17
    Blown and Stroked TNTramair's Avatar
    philly
    2000 trans am ws.6
    3 stage dry sheetmetal intake with plate...
    Three total stages, two via the plate and one via the direct port. All three stages are controlled through our in house controller, the Interface's big brother. I'm going to try to post of some picts of some others in the pipeline, a few more sheet metal and some FAST's. I'll try grabbing some of the 105mm sheet metal that is being finished up now, which has two wet direct port stages.
    Higher res picts can be found here:
    http://www.harrisspeedworks.com/gall...s.php?album=58
    enjoy!!
    2000 WS.6 Trans am M6
    402 W/APS Twin turbos for support...
    1999 Firebird Formula Hardtop M6
    www.cardomain.com/id/twinturboramair
    NW Chitown
    2002 WS6
    Wow. Have you guys published any flow data on the intake itself? Regardless, it sure does look sexy!
    | '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
    philly
    2000 trans am ws.6
    its a Beck intake with custom HSW engraving. you can check out his website for info on the intake itself. http://www.beckmechanical.com/
    Member transam98's Avatar
    Herrin, IL
    2003 Ram 2500
    Thats pimp.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Looks good. Is that one for the L92 port head?
    I know someone that is doing a 2 stage plate and fogger set-up on a Hogan intake. I'll try to sneak a few photos.
    philly
    2000 trans am ws.6
    this one is for a standard ls1 "style" head. ill try to post some more pics when its installed on one of the shop cars and give out more info on the set up.
    I Like It Stroked 99Ls1fever's Avatar
    Greeley,Co
    Artic White
    1999 Z28 408 Stroker M6
    That has to be one of the sickest intakes I have ever seen... Where else can you buy sheetmetal intakes at? and what horsepower should you have to run the sheetmetal intakes?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by 99Ls1fever View Post
    Hogan's Racing.
    http://www.hogansracingmanifolds.com/
    I know someone that just paid $4200 for there's for a LS motor with fogger bungs and 4 nitrous burst plates.
    If it's not an all out race car there would be NO need to spend that kind of money on a intake manifold.
    Wilson Manifolds also makes a sheet metal one for around $3000.
    http://www.wilsonmanifolds.com/
    philly
    2000 trans am ws.6
    yeah...sick manifolds!!
    the reason we went with Beck is basically because it fits under the cowl without modification which makes life easier.
    as Ls2tuner stated, if you dont plan on running a high HP motor you really wont benefit from it.
    Member maxpit's Avatar
    San Diego, CA
    pewter
    02' Z28
    Does a 441ci LS2 based motor qualify? How bout if it has ported L92 Heads, do u think it could benefit from these?
    Greeley,Co
    Artic White
    Quote Originally Posted by TNTramair View Post
    How much do those beck manifolds run?
    philly
    2000 trans am ws.6
    Quote Originally Posted by maxpit View Post
    sure...bigger cubed motors that demand alot of air...nitrous motors...forced induction will benefit from an intake like this.
    on a heads and cam 346...it would be overkill...lol
    philly
    2000 trans am ws.6
    really depends on your application but generally about $2500-$3000.
    Greeley,Co
    Artic White
    Nice Nice what kind of horsepower should I have to run these kinds of intakes???
    philly
    2000 trans am ws.6
    i would say if your plannin a big cube build with either forced induction or Nitrous a sheetmetal intake would be a good idea if money allows it to be. its stronger than a composite intake so we use it for that little added security....and of course, flows a little better so obviously makes a little more power.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Here is another company that has done one for a friend it was $1860 shiped.
    http://www.weinlemotorsports.com/intakes.php
    Greeley,Co
    Artic White
    That is intense manifold, and looks even better....
  1. Help: sheetmetal intake
    By mark21742 in forum Internal Engine
    Last Post: 01-29-2010, 06:35 AM
  2. Replies: 3
    Last Post: 02-05-2008, 08:41 AM
  3. John Stewart Sheetmetal Intake w/90mm TB
    By Hodgesz28 in forum Parts For Sale / Trade
    Last Post: 04-06-2007, 07:07 PM
  4. 90mm Aluminum Sheetmetal Intake Manifold
    By xssive in forum Parts For Sale / Trade
    Last Post: 03-25-2006, 12:00 PM
