Results 1 to 14 of 14
01-14-2008, 03:47 PM #1
Trouble codes throwin on ses light
i have 2 trouble codes - p0174, p0171.
i just changed the front o2 sensors and spark plugs saturday and i had a few backfires after changing them.2000 white z28, t-tops, free mods, intake, full exhaust, dyno tune, repro c5 z06 wheels, and some elbow grease here and there.
01-14-2008, 04:04 PM #2
those codes are for Bank 1 And bank 2 running lean. Did you use the correct 02 sensors? Break any vacum lines? Was the problem there befor you changed the plugs and sensors? wires tight? What were the plugs gapped at?
mods? Also check your fuel pressure, pump may be going south on ya
01-14-2008, 04:06 PM #3
- Nashville, TN
Codes are system too lean bank 1 and 2. Check for vacuum leaks (hoses left off or broken). Check fuel pressure.
01-14-2008, 04:10 PM #4
- Apr 2007
- Watertown, New York
Navy Blue Metallic- 2002 Z28
did you break a plug when you installed it?
01-14-2008, 04:11 PM #5
i used bosch o2 from autozone and it looks like a vacum line coming out of the header on the passenger side is split a bit where the clamp goes right on the header. i gapped the plugs at .044. the same codes were there and some more specifically stating defective sensors. which is why i changed the front ones. but the 2 codes that still exist show the maf from the paper i got from autozone. slp lt headers, slp lm1 exhaust, slp lid, slp smooth bellow, slp CAI, K&N air filter, SLP MAF.
01-14-2008, 04:14 PM #6
no broken plugs either but i just noticed the vacum line on the drivers and passengers side are split at the clamp the attaches it to the headers
01-14-2008, 04:16 PM #7
I think you're talking about the a.i.r. system hoses right? They hook up to the ports in the headers? If that's the case and they're leaking that's where your codes are coming from most likely.
01-14-2008, 04:21 PM #8
i thought it was a vacum like system but ill see if i can get those replaced today or tommorow
01-14-2008, 05:22 PM #9
is the ses light supposed to shut off or am i supposed to delete it to see if it comes up again. i changed the hoses on both sides and it seems to be running the same no backfires but it shakes a bit when im stopped for about 30 seconds or more. sometimes it will delay the throttle and not start moving for a sec. this has only happened 2 times since i bought it but it will shut off while idlin for a while
01-14-2008, 05:29 PM #10
I've heard those Bosch 02 sensors are pieces of sh#t.
01-16-2008, 02:32 PM #11
i changed those 2 hoses but it didnt make any good difference. and the backfires never went away they just arent frequent
10-14-2008, 03:51 PM #12
- Oct 2008
- San Diego
Pewter- 1999 Camaro Z/28
Hey man i'm running a couple of trouble codes myself that i cant figure out. i apologize i'm barging in on your posts here but i cant figure out how the hell to post a new one cause i just signed up today. anyway, i have a 99 z28 which is running all stock except for 4.10s in the rear, slp loudmouth2, and an airbox off a corvette. right now i'm throwing up three trouble codes and was hoping you could help me out. i have a p0410, p0412, and a p0418. any ideas?
10-14-2008, 04:53 PM #13
- Jul 2005
- Jacksonville, FL
Those are all secondary air codes - first thing I'd check is the AIR PUMP fuse if stock. Maybe secondary air was deleted? You can look them up individually for your year at gearchatter.com. Welcome to the board.
10-14-2008, 04:58 PM #14
Help: throwin codes
By Red 99 T/A in forum Firebird / WS6Replies: 0Last Post: 07-25-2010, 07:14 PM -
throwin codes
By grouch0jr in forum Computer & TuningReplies: 18Last Post: 07-14-2009, 04:12 PM -
Question: Trouble Codes
By TransAmFanatic in forum General HelpReplies: 9Last Post: 09-19-2008, 12:15 PM -
Trouble Codes!!!
By 2MuchFun in forum Computer & TuningReplies: 11Last Post: 06-07-2007, 12:50 PM -
Trouble codes need help
By wicked1 in forum External EngineReplies: 2Last Post: 04-10-2007, 10:19 AM
