    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Unhappy Front Shocks/Coils
    I have lowering springs to put on. I took off the driver side and compressed the spring then removed the nut on top. I could not however remove the top afterwards. Is there a trick to this, or will I have to buy new ones?
    Cookie Monster LukesSpeedShop's Avatar
    Watertown, New York
    2002 Z28
    Make sure that you spring compressor good, then put the nut back on loosely, then tap the nut with a hammer, or you can try to slowly, repeat, slowly let the spring uncompress, and the pressure of the spring will pop the top off. I dont reconmend that if your not completely comfortable with it, as ive never done it myself.
    Austin, TX
    99 Trans Am(sold)
    Guess I should've mentioned that I had full spring pressure on it with the nut off and hit it a bunch of times with a hammer and it didn't budge.
    Brookville, PA
    2001 Z28
    It's rusted on. And PLEASE put a spring compressor back on, with at least some tension on it. If that spring would have popped loose, you literally could have lost your head. Only about 1500 pounds of force on a stock spring compressed enough to take it off the car.
    Bottom line: You need to forget the whole shock because at this point you'll be cutting something to get it apart (usually the shock shaft itself). The upper mount it junk because it's stuck on. If you cut the old shock you can salvage the lower isolator which you need and if you have shocks that don't come with a spring perch, that too. You need at minimum upper mounts and hardware, and a new shocks.
    Sam Strano
    SCCA National Champion (x6)
    SCCA ProSolo Class Champion (x5)
    2009 SCCA ProSolo Overall Champion
    Owner--Strano Performance Parts
    814-849-3450
    Jan 2008
    texas
    great information!
  1. Chevy El Camino Front Bushings, Shocks, Drop Coils
    Last Post: 09-28-2009, 10:20 PM
  2. Front and Rear QA1 shocks with front QA1 springs
    By 1BadCamaro in forum Parts For Sale / Trade
    Last Post: 08-09-2007, 04:16 AM
  3. shocks and coils
    By newcomer in forum Suspension and Handling
    Last Post: 06-13-2007, 11:52 AM
  4. shocks and coils??which ones
    By 94formulaLT1 in forum Suspension and Handling
    Last Post: 03-20-2006, 07:31 PM
  5. FS: SFC & Trick front coils 67-69 Camaro/Firebird
    By BBBBadSS in forum Classic Muscle
    Last Post: 02-28-2006, 05:21 PM
