Results 1 to 11 of 11
    Member CJREX's Avatar
    GA
    Gone:2001 Camaro SS #4846
    Head Unit Doesn't "See" CD Changer
    I recently posted a thread about a CD changer I picked up.
    After some wrangling I got it work (2 of the trays had bent fingers. Straightened them and it functions normal mechanically.)
    My problem now is that I can't access the changer from the head unit.
    I disconnected the battery for an hour to see if it would find it when reconnected but no luck.
    Any suggestions?
    Thanks!
    Union Beach, NJ
    triple black
    02 z28 m6
    trying putting the cds in upside down
    Rockford, IL
    GA
    The discs are loaded correctly, ie the labels are facing down with the read side facing up.
    Union Beach, NJ
    triple black
    02 z28 m6
    the only other time ive had that problem it ended up being because i didnt have a cd in the first slot
    GA
    I have a CD in the first slot but I realized that I only have 11 slots.
    The 12th tray is missing.
    Could someone remove one tray from their cartridge and see if it does the same thing?
    R/A T/A SS/CETA's Avatar
    Arkansas/Missouri State Line
    Collector Yellow
    2002 Pontiac Trans Am CE
    It's the same as only loading 11 of 12 trays. It makes no difference if all the trays are in at the same time. like someone else said:
    You need a disc in slot 1.
    And they are label face down from the factory.
    If it's throwing codes, look up the code number and it will define your problem.
    Rockford, IL
    i dont have a disk in slot 1. works fine
    GA
    No codes are ever thrown.
    It's as if the head unit doesn't even know it's installed.
    Collector Yellow
    It might not. You may need to schedule an appointment at your local stereo shop and have them diagnose the problem. If your savvy with electronics, though, you could probably trace the wires to see if there's a bad ground somewhere you can't see.
    GA
    After trying everything I can think of, still no dice.
    Anyone in the Atlanta/North GA area with a factory changer want to see if this unit works in your car so I can determine if it's the changer or my head unit?
    I'll pay for your gas to meet somewhere.
    Thanks!
  1. Giuliani: "Obama Doesn't Love America"...
    Last Post: 02-27-2015, 06:19 PM
  2. Replies: 18
    Last Post: 04-21-2007, 07:07 AM
  3. Replies: 10
    Last Post: 02-28-2007, 10:38 PM
  4. Replies: 17
    Last Post: 06-21-2006, 03:30 AM
