01-13-2008, 08:54 AM #1Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Light Pewter Metallic- y2k 8-cylinder catfish
Question on replacing factory Monsoon door speakers
Me and buddy were going to replace the factory door speakers in my car with my aftermarket MB Quart speakers but once we pulled back the panel on the passenger side and took the speaker out, we noticed it has two wires running to it while the MB Quart speakers with their crossovers only use one wire. He's not sure if we should mess with it and at this point thinks just having a professional do the swap is the best option. I was trying to avoid shelling out money for a basic speaker swap. Does anyone know what needs to be done?
2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
01-13-2008, 11:01 AM #2Member
- Jul 2006
- Loveland/Ft. Collins, CO
Blue- 2001 Formula Firehawk
i just spliced mine in off both connectors and they work great
01-13-2008, 01:32 PM #3
01-13-2008, 01:44 PM #4Senior Member
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
when i did mine i took one black wire from one set of the four wires and one red one, (one from each set of wires). you will have to try them both to see which two it is.
are you replacing them with 4 ohm speakers or 2ohm's?
stock speakers in the front door are 2 ohm's
the 4 ohm's are going to pull more power than the stock amp can handle so it wont be using the full potential of the speaker at higher volume.1999 Camaro SS/ Pewter/ #1775 - LS1 6-speed - Predator 3 Custom Tune - Pro 5.0 - LS7 Clutch - 3.90's - Koni's - Strano Springs and Sway Bars - SFC's - Full UMI Chassis and Suspension - LS6 Intake PnP TB - ARH LT's and Kitty Ran Away - Magnaflow.
12.6 at 112
01-13-2008, 02:26 PM #5Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Yes, the aftermarkets are 4 ohm with crossovers.
monsoon door speakers
By 0rion in forum Parts Wanted / TradeReplies: 2Last Post: 03-25-2009, 05:01 PM -
Help: replacing rear monsoon speakers help??
By tjclt250r in forum Firebird / WS6Replies: 1Last Post: 06-05-2008, 10:41 AM -
Who else has replaced their factory Monsoon speakers?
By SiggyZ in forum Stereo and ElectronicsReplies: 1Last Post: 02-05-2008, 10:34 AM -
replacing monsoon speakers...
By blackmagic00 in forum Stereo and ElectronicsReplies: 10Last Post: 09-30-2007, 08:23 PM -
wtb monsoon door speakers
By jimmyboy8301 in forum Parts Wanted / TradeReplies: 2Last Post: 05-20-2006, 10:48 AM
