    calif
    2001 Camaro SS M6
    need to add new water drain holes to hatch?
    I have a 2001 SS and whenever it rains, ~1 qt of water accumulates inside the hatch assembly and runs out of the front hatch drain holes when I raise the hatch ( and quite a bit gets into the car). There are two "plugs" near the back of the hatch that look like might be lower and a way to keep rain from building up in the hatch. Anyone had this problem? how did you solve it?
    Bragg NC
    Met. Sunset Orange
    01 SS
    i had water getting into my hatch area, or the lowest portion of the hatch, anyhow, its because when i was driving in the rain it was being kicked up by my rear tire and being splashed into the hatch area. Some sealent and i was good to go.
    J
    calif
    2001 Camaro SS M6
    I think problem is a drain hole issue
    sunsetorangess,
    thanks for your reply. As a further clarification, it looks like the water accumulates in the glass channel and since there is no drain at the center back of the window, the water drains along that channed when I open the hatch. Looks like other that putting some sealant in that area, I'm stuck with another case of form vs. function.
    maine
    2002 z-28
    i have the same problem........just open your hatch a little slower so the water drains without building up and splashing into the hatch area ..thats what i do
    Bragg NC
    Met. Sunset Orange
    01 SS
    Quote Originally Posted by 2002ls1 View Post
    Should do the trick..
    J
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Is the rear of the seal in good condition? The hatch could also be out of alignment.
  1. Some ppl are just A-holes
    Last Post: 12-10-2013, 12:46 PM
  2. Help: '01 Ram Air TA Rear Hatch Lift Strut Mount loose in Hatch
    By NAVYGSE1 in forum General Help
    Last Post: 12-20-2011, 01:07 PM
  3. Replies: 15
    Last Post: 05-15-2011, 09:28 PM
  4. TFS steam holes?
    By garygnu65 in forum Internal Engine
    Last Post: 03-21-2010, 06:47 AM
  5. Help: water leaking from hatch
    By sd1971 in forum General Help
    Last Post: 02-09-2009, 06:19 PM
