Results 1 to 10 of 10
    La Crescenta
    2002 TransAm Firehawk
    Best OBD II Scanner?
    Any recommendations on a OBD II Scanner. I have 42 K Miles on my Firehawk and the SES just came on. I'm going to buy a code scanner. Cheapy's cost around $30-$60. Better one's around $130-$200. Any reason why I should buy more expensive units. I have a code list in my Haynes Repair Manual.
    Senior Member
    Jacksonville, FL
    If all you want is to read/delete codes get a cheapie - harborfreight sells one for about $40 last time I checked. Or you can have someone like Autozone read it for free. No reason to spend more unless it'll read "real time data" too.
    Kill Whore LS1What's Avatar
    West MI
    '85 GT
    Snap On MT2500... That's what I've got, of cousre it's professional grade. Alot more then what you're willing to spend I reckon. Nothing beats Autozone's free scans..
    Member LS1Z28's Avatar
    Lake Elsinore,CA
    Camaro
    If you want the best get a Tech 2.
    West MI
    '85 GT
    Quote Originally Posted by LS1Z28
    Yeah, well when it comes down to a scanner/data logger that'll provide a GUI with real time data. With a shitload of removable hardware modules.. They're all really the same. Just cause GM Tech's use it... It's just as great as any other with it's same opotions..
    La Crescenta
    Didn't know Autozone did it for free. I'll try that first.
    Thanks.
    Senior Member
    Jacksonville, FL
    Write down the code and post it...maybe we can help.
    La Crescenta
    Went to Autozone and had to put a credit card deposit of ~$185 to borrow their scanner. Got a code P0113 indicating high input on IAT sensor. Lifted the hood and realized I forgot to reconnect the lead to the IAT sensor over the weekend when I was taking a look at what it would take to perform the MAF coolant bypass modification. Erased the error code with the Scanner, reconnected the IAT sensor and problem solved.
    I'll probably end up buying one of the $50-$70 scanners on Ebay just so I can save having to go to Autozone next time.
    Thanks all for the help.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Quote Originally Posted by race5050
    MPFD
    Guest
    If you want the best order LS1 edit. It cost about the same as a scanner but you get so much more!!!
  1. Question: how is this diagnostic scanner?
    By SteveCZ28 in forum Computer & Tuning
    Last Post: 02-06-2011, 08:53 PM
  2. Cheaper to buy new scanner than ink!
    By Larry in forum Computers / Gaming
    Last Post: 03-29-2010, 04:58 PM
  3. autotap scanner vs hp scanner
    By formula99pewter in forum Computer & Tuning
    Last Post: 02-11-2009, 11:00 AM
  4. Anybody have an LT1 scanner???
    By SSmaro in forum Rocky Mountain Members
    Last Post: 03-06-2007, 07:17 PM
  5. WTB GM Tech 2 Scanner
    By Frozen WS6 in forum Parts Wanted / Trade
    Last Post: 09-12-2006, 08:57 PM
