    Feb 2006
    GARDEN GROVE, CA
    BLACK
    2002, CAMARO Z28
    cooling fans won't run on high
    I've had them programmed for a while with a predator to run cooler and all the sudden they wont run on high, only low. What should I check?
    Senior Member
    Jacksonville, FL
    It should be throwing a code if there was a fan/relay issue right? I've got mine set 194/185 for high speed and since it's cooler now they rarely run at high speed (I have LEDs and can see them come on). Since you have a Predator I'd look at real time data/ECT temp and make sure you're meeting the threshold for them to come on first.
    Feb 2006
    GARDEN GROVE, CA
    BLACK
    2002, CAMARO Z28
    On live data the ect's are 20 degree's higher than usual with the fans reprogrammed. The low fan setting do work though. I have unloaded and reloaded the predator tune a few times and nothing. I found online that the No. 2 relay controls the high speed setting. I'm gonna replace it.
    Senior Member
    Jacksonville, FL
    Don't know if it makes a difference, but maybe the temp settings are overlaping? Here's what mine are set to just for info:
    Fan 1 (low) - on 184/off 175
    Fan 2 (high) - on 194/off 185
    Still think you'd throw a code if it was a relay.
    Senior Member
    Jacksonville, FL
    More info on fan/relay operation here under diagnostics for P0481. www.gearchatter.com/viewtopic8997.php
  1. NO high speed cooling fans
    By JaySleazy in forum General Help
    Last Post: 02-21-2011, 05:19 PM
  2. Ls1/lt1 cooling fans
    By QKRDTA3 in forum Parts Wanted / Trade
    Last Post: 07-03-2009, 05:58 AM
  3. cooling fans won't run on high
    By occamaroz in forum General Help
    Last Post: 01-11-2008, 03:14 PM
  4. cooling fans
    By 79Malibu in forum Stereo and Electronics
    Last Post: 04-27-2007, 07:00 PM
  5. 98 LS1 cooling fans?
    By tigressws6 in forum General Help
    Last Post: 03-19-2006, 02:55 PM
