Results 1 to 20 of 20
    Member T/A36's Avatar
    Fremont, IN
    1999 Trans am WS7
    What guages should i get?
    Hey i just bought a tripple guage pod and im wondering what you guys suggest i should put in there. I only plan on doing the following mods....
    Slp lid
    New T/B and intake
    Mild cam
    Lts, ory, cat back
    gears
    shift kit and stall
    small shot of nitrious
    tune
    What do you guys think? THANX
    Travis
    Junior Member BirdFlewLS1's Avatar
    I sleep in the house...Live in the shop
    midnight Blue
    '99 Trans Am ws7
    Looks like we're in the same boat...i donno wut to get or how to go about hook them up to an ls1
    Member krusemj's Avatar
    where ever the army wants me to be
    artic white
    2001 WS6 Trans Am
    If it me I would put in a fuel pressure and no2 pressure for sure.
    down with the lot lizards blackhawk01's Avatar
    Pensacola
    2001 Camaro SS A4
    lol..im in the same boat as well..would like some suggestions
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    I did the fuel pressure / NOS / wide-band !
    Fremont, IN
    1999 Trans am WS7
    Quote Originally Posted by bills98ta View Post
    Thats what im going to do. thanx!!
    Feb 2007
    St Thomas, PA
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    Fuel pressure, N2o pressure, and tranny temp.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    midnight Blue
    '99 Trans Am ws7
    how do you hook up the fuel pressure gauge?
    Feb 2007
    St Thomas, PA
    Quote Originally Posted by BirdFlewLS1 View Post
    The fuel rail has a pressure tap that you remove the cap & valve stem, then hook the sending unit to it. Be careful not to over tighten & twist the fuel rail ! If you have a NOS presure switch, you need a T fitting to hook up both ! Good Luck !
    midnight Blue
    '99 Trans Am ws7
    hey thanks for the quick reply man...thanks again
    Feb 2007
    St Thomas, PA
    That's the easy part ! Getting the wires run into the car is the challenge !!!
    midnight Blue
    '99 Trans Am ws7
    yeah i knew that when i ordered them....its a never ending battle. but its needed and worth the hassle. also to hide the wires is fun to...i like stock appearing besides the lingenfelter intake and lid.lol
    how far does the fuel pressure gauge need to go? 0 to 15 or 0-100 psi
    Pensacola
    2001 Camaro SS A4
    does anyone have any suggestions to where there is already a pre drilled hole in the firewall of the car that ill be able to run the wires through when I decide to put mine on?
    Feb 2007
    St Thomas, PA
    I drilled a hole beside the steering column from the inside, above the carpet. Accessible below the brake booster...
    well, at idle your fuel pressure should be 58psi so you'll need the 0-100psi. Also, if you drill your own hole in the firewall make sure you put a grommet in it so the wires don't end up chaffed. You can get grommets at just about any parts store and they're cheap.
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    Quote Originally Posted by blackhawk01 View Post
    there is a gromet in the firewall on the passenger side near where the computer sits in your engine bay.
    Pensacola
    2001 Camaro SS A4
    awesome..thankyou
    midnight Blue
    '99 Trans Am ws7
    does fuel pressure go down as you drive? or rev? all i can find in my gauges are 0-60psi in the in the white faced gauge
    Feb 2007
    St Thomas, PA
    It might drop under heavy loads, but should hold around 58lb or so... You might get away using the 0-60 guage... If it would drop a lot, you might want to upgrade the fuel pump !!!
  1. Guages
    By Motomas in forum Stereo and Electronics
    Last Post: 08-22-2009, 01:34 PM
  2. 1st gen guages on 4th gen?
    By Frankthetank in forum Appearance Section
    Last Post: 11-16-2007, 04:51 PM
  3. Who has the most guages
    By Sarge in forum GTO
    Last Post: 05-19-2007, 04:32 PM
  4. 1pc wht face guages or 3pc ??
    By greatwhiteZ28 in forum Appearance Section
    Last Post: 03-25-2007, 04:59 PM
  5. Guages I got...
    Last Post: 03-27-2006, 09:15 AM
