Thread: How much abuse can a LS1 handle
01-09-2008, 04:53 PM #1
I currently own a 2000 TA M6 with 85k miles on it. I have one of the hardest times staying out of the throttle. I always use Mobile 1 synthetic, but I was wondering how much abuse will these engines be able to withstand being mostly stock?
01-09-2008, 09:35 PM #2the cake is a lie
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
quite a bit. i broke my flexplate at the mounting bolt holes
01-09-2008, 09:35 PM #3
about 600 horsepower and the rear end will go out before the endine usually does. you will come to find that mobil 1 is not the best oil out there and that pennzoil platinum has bettering shearing charecteristics and costs less. you being a new member i would advise you to just read lots of posts it is amazing how much i have picked up in 5 months time
1998 Firebird Formula WS6... few things done.
01-10-2008, 03:27 AM #4
Yepp, like said above use the search button and goto town. Should be able to find what your looking for. Internaly iv found that your rod bolts, and pushrods are pretty weak links, but not until upwards of 500hp would i worry about the rod bolts.
Also your rear is probly the weakest point in your driveline from the factory, Our stock 10 bolts wont hold up to much. As far as the motor, if your stock, then goto town. Also search around the site there are alot of post's about better oils to use, Mobil 1 use to be synthetic but not anymore.
Sarge has posted a boatload of info on oil's and there pro's and con's.
J
01-18-2008, 09:34 PM #5
Thanks for the info. After reading alot of the reviews I changed to Penzoil Platinium. Cheaper and less shearing rate, cant go wrong there. This website saves me alot of ?s I have, its great.
Dolphin abuse
By Dabom75 in forum Almost Anything GoesReplies: 9Last Post: 07-04-2011, 01:41 PM -
Abuse mode
By aviatorSS in forum Computer & TuningReplies: 14Last Post: 02-22-2008, 03:48 PM -
Tire Abuse Vid, New Rims Pics
By Styke in forum Wheels and TiresReplies: 6Last Post: 11-04-2007, 08:11 AM -
How much abuse and or HP can my A4 handle??
By Mustang Killa in forum Automatic TransmissionReplies: 19Last Post: 10-03-2007, 07:52 AM -
Viper abuse on video!
By Toolman in forum Almost Anything GoesReplies: 24Last Post: 02-27-2006, 04:40 AM
