Results 1 to 10 of 10
    Member blk_jaws's Avatar
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    Power steering pump
    what does it sound like when the power steering pump is about to go out?
    Senior Member
    Jacksonville, FL
    Is it making noise? I'd check the fluid level/check for any leaks. Noise on start up could also be a bad pulley.
    Virginia Beach, VA
    2000 SS
    Could be anything from a persistent low groan, to high pitch metal-to-metal sound.
    Never hold the wheel at full lock for an extended period.
    Junior Member kevinpickering's Avatar
    Warrenton, MO
    Blue
    1999 Camaro SS
    Mine went out last year and started to whine when you turned the wheel one direction. It was kind of a high pitched whine. I bought a new one and installed a cooler in-line with the return line. Works great now. Hope this helps.
    i think....wait...i know i have a bad steering return pump, i've also noticed the color of my steering fluid is like murky-brown...is that right???
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    It was'nt the pump, all the pulleys needed replaced and the belts too.
    Thanks for the replys though
    nj
    90 Mustang 5.0
    sometimes pumps get air in the system and will make noise. sometimes the fluid is low and will make noise. sometimes a pully is bad. sometimes the bearings in the pump are bad. any of these will make a loud groaning or screeching sound. very annoying.
    ALLL OF THE PULLEYS?!?!?
    damn..that had to be expensivve
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    for 2 of them and labor it was $99. But they had to order the other two, so I'm hoping it isn't that high also.
    Member 6sw00's Avatar
    N.Y
    2000 trans am ws6
    im having that problem. the noise is so annoying. just about constant. how do i check to see if its the pully?
  1. Help: power steering pump
    By whiteta in forum External Engine
    Last Post: 08-30-2009, 05:20 PM
  2. Power Steering Pump
    By OnEbAdReDSS in forum External Engine
    Last Post: 08-26-2008, 10:17 PM
  3. Power Steering pump leak?! new pump or seal kit?
    By JehalinTA in forum General Help
    Last Post: 03-18-2008, 10:05 PM
  4. power steering pump for 00 Z28
    By StaySydewayZ28 in forum Parts Wanted / Trade
    Last Post: 09-04-2007, 06:24 AM
  5. Power Steering Pump Going?
    By Neil in forum General Help
    Last Post: 03-03-2006, 04:15 AM
