08-12-2005, 06:55 PM #1
dyno results swapping from 3.23 to 4.10 auto
08-14-2005, 09:04 PM #2
Re: dyno results swapping from 3.23 to 4.10 auto
good info
08-16-2005, 09:07 PM #3CamaroSSx1999Guest
so... swaping to 4.10's u lose horse and torque?
08-17-2005, 09:25 AM #4
08-20-2005, 11:12 PM #5CamaroSSx1999Guest
so is that the same for a m6
08-21-2005, 07:35 AM #6
08-21-2005, 09:25 PM #7CamaroSSx1999Guest
so im planned on putting 4.10's in my SS, i already bought them from a friend. their grinded down on two sides, he said the person who put them in have to get them in. does that sound right? ive never change gears.
also, if i lose hp? with the 4.10s will it still make my car faster? what kind of gains can i expect?
08-21-2005, 09:29 PM #8
my motive gears fit right in. i had to grind down the axle spacer that goes into the carrier to clear the ring gear. i didn't grind the gear.
08-22-2005, 01:13 PM #9CamaroSSx1999Guest
these are GM 4.10's, their grinded down on two sides of the rind, just on the very inner sides of the teeth. has anyone heard of having to do this?
08-22-2005, 01:33 PM #10Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Those might have been gears for a 2 series carrier. They might have been done to make them fit on a 3 series carrier.
09-01-2005, 11:47 PM #11
where both runs done with a twelve bolt? I am assuming that they were.
09-02-2005, 01:15 PM #12
mine were done with the factory 10 bolt, not 12 bolt. the only change was the gears.
Question: Do these dyno results seem right?
By egldriver in forum Computer & TuningReplies: 8Last Post: 01-04-2016, 03:56 PM -
Thinking about swapping 6spd for auto
By Whiteboycntdnce in forum Automatic TransmissionReplies: 3Last Post: 04-30-2008, 06:31 PM -
Dyno results
By bguns10 in forum Dyno InformationReplies: 6Last Post: 06-29-2007, 04:29 AM -
Help swapping 2000 ls1 6 speed to a 97 rs auto
By dae04383 in forum General HelpReplies: 2Last Post: 07-18-2006, 05:56 PM -
1st dyno results
By white01ws6 in forum Western MembersReplies: 6Last Post: 03-10-2006, 03:29 AM
