Results 1 to 11 of 11
Thread: starter help
    Florida
    2000 Z-28
    starter help
    My car is sometimes not starting....as of yesterday. I put it on the charger and the battery was fully charged and this morning, nothing, tried again and nothing, tried the third time and she started right up.
    I think its time for a new starter? Any recommendations for the starter and is it easy to replace myself?
    Thanks.
    She has 94k miles on her and a Optima yellow top (10 mos old).
    Member Z34LS1's Avatar
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Are you sure it's the Starter? Did it Crank Slowly with a Full Charge? It sounds like mine did when my Fuel Pump was taking a crap. Wore the Battery down cranking it over, then I thought maybe my starters not cranking it over Fast enough. Take the starter off, and have it tested. Most places can tell you how many Amps it's pulling. The Starter is not a tough job to do if it's that. Your Battery could be taking a charge but not holding it, How old is the Battery?
    Florida
    2000 Z-28
    My battery is only 10 months old and I put in on the charger last night and took it off this morning and immediately started the car. There was nothing happening, then I tried again, and nothing....then on the third turn of the key, the car started as if nothing was wrong. Strong and immediate start.
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Sounds like your Starters Solenoid is taking a dump.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Was your security light flashing at you or was it on? Check your terminals and make sure they are good and tight and clean, also check the wiring on the starter itself.
    J
    Orlando, FL
    Want a new car
    That's my first suggestion to check battery connections for tightness and corrosion, next check the battery with a good tester (my need to go to a autozone or something) I have my own because I used to work in a battery shop, it should be able to test the charging system and the battery under load, sometimes the battery will look good but put a load on it and it my not handle it. cold weather makes the worst come out in a battery. I would also check the connections to the starter.
    Florida
    2000 Z-28
    any recommendations for replacement?
    Orlando, FL
    Want a new car
    I got a Bosch in mine, low cost and should last just as good as any.
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    At this point DON'T REPLACE ANYTHING. You need to have it checked out before replacing anything. There is Great Advice just above.
    1) Visually Inspect all conections.
    a) Battery Terminals
    b) Starter wire connections. (this means getting your F Body up on some ramps(be careful of Lower air Dam) and looking at the wires themselves and if possible reach your hand up in there and see if each wire is secured tightly(watch out for Hot Exhaust pipes)).
    c) Ground cable off Battery to Frame.
    What's listed above you should be able to do with a Buddies Help.
    Next...
    If Everything looks good that's listed above take the car to Autozone as stated above, or ANY OTHER AUTO PARTS STORE that has the ability to check:
    1) Your Vehicles Charging System(Alternater and charging circuit)
    2) Your Battery
    3) Your Starter
    The 3 Steps listed Above usually don't cost Anything, at least most Auto Stores around here want your Business, So they are more than willing to do All kinds of Stuff to HELP you out.
    Next to the Bad News.....
    If you've done All of the above, And EVERYTHING checks out Good, Your Car needs to be Serviced to find out what's wrong. Usually it's #2, or #3, but many times it's connections on the wiring or the wiring itself. If the Starter or Alternater was replaced by someone who did not Secure the wires from Harms Way you may have a cut, burnt, or damaged wire. That wire could be grounding out, or not making a connections.
    You can figure this out I bet, and you'll become more familar with your car in the process.
    Best of Luck, and Report Back with your findings.
    Joe
    Bragg NC
    Met. Sunset Orange
    01 SS
    Nice wright up Joe...
    J
    Florida
    2000 Z-28
    Thanks Joe,
    I am the original owner and the alternator and starter have never been replaced. I will get under the car and check it out. If all is well, iwill follow your advice and take her to advanced auto to check the system out.
    Steve
  1. it is the starter right?
    By jondev in forum External Engine
    Last Post: 09-29-2008, 03:48 AM
  2. WTB....starter
    By 1tonzr2 in forum Parts Wanted / Trade
    Last Post: 03-11-2007, 08:02 PM
  3. Starter Going Bad.. HELP
    By LS1_WS6_TransAm in forum Firebird / WS6
    Last Post: 01-15-2007, 12:51 AM
  4. Bad Starter??
    By Wikid NaSSty in forum General Help
    Last Post: 09-25-2006, 10:59 PM
  5. Does this mean I need a new starter?
    By AKIRA in forum General Help
    Last Post: 08-12-2005, 09:37 AM
