Results 1 to 14 of 14
12-31-2007, 01:09 PM #1
Anyone doing any major mods for this up coming summer?
Well Race season is about 3 1//2 months away now! Im excited to get ack racing if I can get my car finished.
So what all mods have you guys done over the winter and what are you looking to get out of your ride this year?
I have been working weekend to weekend trying to get mine were I need it. I just got the motor pulled last weekend and wiring out. going to sand blast the engine bay tomorrow and get ready paint. Also installing my new turbo, along with new wiring harness, Launch control, Injectors, Fuel rail, Exhaust manifold, Power Commander, and Roll cage installed.
Im looking to get 650-750 RWHP this year out of my 240 and hoping to get it in the low 6's to high 5's in the 1/8 mile. I just hope my rear end holds up!!
01-01-2008, 03:35 PM #2
wow looks like your doing alot, but for me its just the little stuff.
so far since my 12.27 run i have removed 58lbs, relocated the battery to the trunk, changed the 2-3 shift from 6500 to 6200(keeps it in its power band), and replaced my steel driveshaft(19lbs) for an aluminum(11lbs) other then that i want to see what it will run with those changes. hoping for an 11.99 and a 1.69 60' at about 112 or 113 mph, but most likely it will run in the 12.0 range.
if that doesn't get me there will order the light weight k-member(30lbs) and a fiberglass hood for another 25lbs. 11's are very close
after all this is done it will get some afr 205cc heads with a good cam2000 auto camaro
13.54 @ 104 2.049 60' stock 2.73
12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
01-01-2008, 05:06 PM #3
Nice!!! Sonds like you will be in the 11's.
Are you still running the stock rear end?
Those heads and cam combo should get you there without removing any more weight.
01-11-2008, 10:47 AM #4
I took almost 200 pounds out of my car and put some 40" wheel tubs in it, getting a new rear end, Torque Arm setup and new c-moly drive shaft.
Then going to get some 29x11.5 hoosiers for it until I buy my 15x12's, then I'll go to a 30 or 31 x 14" section tire.
Pretty happy with it, still have the back seat too.
Oh did some custom stuff, moved the factory shock in 1" and moved the lower control arms in about 2 more inches, so the tub to fender is 17" and I have 16.5" from the lower control arm to the fender for clearance.
So basically 16.5" to stuff a tire into.
Then I am getting my rear narrowed 4.5" per side and using my rims I have now, then later I will get a 15x12 with 5" back space and put the 30 or 31" tire on it.
01-12-2008, 05:20 PM #5
Sweet dude!! Post some pictures when your done! I would like to see.
Well I decided to scratch all my Upgrades on the fuel part. I decidd to go back Propane.
So I still have the engine out and working on a tight schedule to get everything done.
01-15-2008, 07:15 PM #6
Uncle sam F-ed me this rear was hoping to get more money back for the family come tax time
Can't wait to just drive it, think I'll throw a small nitrous kit on it to play with till I can afford to build an FI combo. Stock crank, with some after market rods and pistons and some nice heads and try to shoot for 800hp on pump gas @6,000 rpm. At least that would be the idea goal.
Then it will be fun
01-23-2008, 01:01 PM #7
in the process...
on order trick flow 13.5 degree heads,trick flow cam 228/[email protected],585/585 lift,harland shop roller rockers,chromemoly pushrods,tsp ported oil pump,90/90fast combo,lt hookers,ls2chain,ls7 lifters and maybe a 100 shot of spray,hope the stock bottom end holds up.previous numbers were 333rwhp 344trq with bolt ons.hoping for 125hp with out nitrous.
01-23-2008, 01:13 PM #8
my lt jet hot coated headers & ory should be delivered any day now
also debating if i should get an electric cut out too?
01-23-2008, 01:51 PM #9
If you're adding all that I would also go with a higher flow rate fuel pump, at least a 255 lph, and if the nitrous kit is a dry kit, with the added power from the cam/heads/intake/exhaust combo you may also want to consider slightly larger injectors.
A tune with that many changes and the addition of nitrous would be pretty much mandatory.
Also consider colder spark plugs and adding some higher octane gas when spraying the car to add some additional safety, as well as pulling some timing when on the nitrous.
Sounds like a cool combo and should be well over 500 rwhp, easily putting you in the 10's with traction and some chassis work, keep us updated and post some photos when you get the goodies
01-24-2008, 12:37 PM #10
01-24-2008, 12:40 PM #1115sec stalled A4
- Dec 2006
- Lake in the Hills
Shhh! There's a- hooker in the trunk
installing my fuddle 3200 with trans cooler, installing a few gauges in the vents, while the trans is out, getting it rebuilt/shift kit installed. need to get my rear bilsteins on too. putting an engine killswitch on. um i think thats it
oh ya getting a major detailing too
02-18-2008, 08:22 PM #12Junior Member
- Nov 2005
- US
- 01 Formula
02-19-2008, 07:04 AM #132 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
Well lets see, In November I put my 9" in. Next week my H&C combo, Fast 90/90, and spec 4 clutch are going in. All I need to buy now are some Micky Thompson stickies.
02-19-2008, 07:18 AM #14
Sounds like your further than me!!
I just got my new radiator Modded to fit, My hood cut out for clearance and some vents fabed up for my electric fans!
I have my new oil cooler on the way, My wiring harness is almost finished, little more soildering and I hope to maybe drop the motor back in late this weekend. Gotta wire up all my new gauges, My roll cage is going in hopefully in 2 weeks, and Im hoping to get my propane kit by the end of March!!!
SO much work!! So little time!
Need major help
By Adam_94_T/A in forum Almost Anything GoesReplies: 2Last Post: 12-10-2009, 07:28 PM -
$$$ to spend on some Mods, coming back from IRAQ
By TX02TRANSAM in forum Firebird / WS6Replies: 24Last Post: 07-06-2008, 12:48 PM -
I Need Major Help!!!!!!
By LT1Redneck in forum LT1Replies: 3Last Post: 06-18-2007, 07:11 PM -
if you plan on major mods please read this
By 0rion in forum Internal EngineReplies: 4Last Post: 04-06-2007, 10:00 PM
