Results 1 to 2 of 2
12-28-2007, 03:21 AM #1
- Jan 2007
- Germany
what length pushrods with this cam...
I've got a XR269-H14 Cam, which I want to use with Harland Sharp 1.8 Rockers, anybody can tell me what length pushrods I need? I have stock Heads and Gaskets, Cam Specs are:
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.525 0.532
Duration At 0.006 Tappet Lift 269 273
Valve Timing At 0.006
Open Close
Intake 23 66
Exhaust 73 20
These Specs Are For The Cam Installed At 112 Intake CL
Intake Exhaust
Duration At 0.05 216 220
Lobe Lift 0.309 0.313
Lobe Separation 114
01-01-2008, 08:58 PM #2
- Dec 2007
- Austin, TX
Pewter- 2002 Trans am WS6 T-top
Iam no means an expert, but the 7.4 lenght rods will work. In all and all, that cam is about two step higher that and oem stick with a stock idle. The differant ratio rocker arms will also help. Basicly, the only time differant lenght rods are need: soild lifters, heads are milled
big time, and exotic rocker arm replacements.
Iam pretty sure if Iam wrong someone will correct me.
Can I stick with stock 7.4 Pushrods or check for length
By cmaross01 in forum Internal EngineReplies: 2Last Post: 08-23-2014, 09:21 PM -
what length pushrods you runnin??
By 1991ls13 in forum Internal EngineReplies: 2Last Post: 06-02-2010, 10:46 PM -
Futral Motorsports 7.4 Length hardened Pushrods
By Damian in forum Parts For Sale / TradeReplies: 0Last Post: 06-01-2010, 10:29 PM -
Pushrod length
By Naf in forum Internal EngineReplies: 2Last Post: 07-28-2007, 05:06 AM -
By silverws6 in forum Internal EngineReplies: 2Last Post: 08-30-2005, 01:33 PM
