    Chas. WV 25303
    WHITE
    2002 Z28
    Staggered Rims - 2002 Z28 w/ TCS & ABS
    i was in the middle of changing summer 20's for winter 17's, had to run out with the front un-changed, turned the "TCS" off and the car started throwing "ABS" codes. got home finished the job and everything was alright.
    so if i do the staggered rim thing will i start to have trouble if i do a 9 inch rear with slicks behind. is there a certain diameter limit that must be maintained between the front and rear wheels. thx
    This thread can probably help you out.
    http://www.ls1.com/forums/showthread.php?t=11359
    Painted manta stripe
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    It's the Overall Diameter that is important... not the size of rim.
    What size tires are you using ?
    Eugenio_SS
    Member rickssz's Avatar
    Feb 2006
    pgh
    I tried 15" ET Street with front skinnies I think app.6 difference and got ABS inop I think the light said. I think the rim and tire sizes dont matter that much as long as there is only a small variance front to rear .
    Chas. WV 25303
    WHITE
    2002 Z28
    staggered rims
    i was using 25.5 inch diameter tire on the rear and a 27 inch diameter tire on the front at that instance. but i wanted to know for future purchases, what will work. i want to go with a 9" Moser and large slicks. will i be able to keep ABS and TCS if the rear tire diameter and the front tire diameter is not planned ahead, which is just in reverse as the rear rim is usually larger as well as the slick. thx
    Chas. WV 25303
    WHITE
    2002 Z28
    staggered rims
    thank you Y2K Pewter SS, with that thread i will be able to pre-select tire and rim and save a bundle of time and money by getting the job done the first time. spordee1
    Jun 2002
    Montreal, CANADA
    triple-black
    try to keep the overall diameter the same... anything over 1" difference tends to give problems.
  1. Question: 2002 Camaro SS Rims
    By 2002 SS Camaro in forum Camaro / SS
    Last Post: 11-12-2011, 02:38 PM
  2. 2002 WS6 rims needed
    By clemy2573 in forum Parts Wanted / Trade
    Last Post: 06-17-2009, 01:31 PM
  3. anyone have pix of there camaros with staggered rims??
    By camarossf650 in forum Wheels and Tires
    Last Post: 11-10-2007, 08:55 PM
  4. Need a pic of staggered rims
    By sk8runeg in forum Wheels and Tires
    Last Post: 02-06-2006, 10:45 AM
