Thread: Pushrods
12-24-2007, 11:23 AM #1
Pushrods
I got a 228r cam and 300stall for xmas and anniversary from my wife. im going to upgrade valvesprings there comp cam springs, my question is whats the stock pushrod length? i want to upgrade those since they will be out of the motor anyway, looking for imput on best bang for the buck on pushrods i guess
12-24-2007, 11:33 AM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
7.4" is the stock height Comp cams are the best, around a c note.. Going through the same ordeal myself!!
12-24-2007, 06:41 PM #3
What about valve springs? what kind? stock heads, also, because this is my dd
12-24-2007, 10:22 PM #4
I run patriot gold dual springs with that same cam but that's because they came with my heads. You can run comp 918's with that cam but I liked the security of a dual spring.
12-24-2007, 11:54 PM #5
I was looking at summit part number cca-26918-16 texas speed has a similar vlavespring but cheaper. how hard is it to switch springs, whats better comp cams pushrods or trickflows? didntmean to use a bit of a run on sentence but its 3am. so new springs, pushrods, 228r cam, tci 3000stall, 373 gears, and what i already have, cai, pace lts, slpcat, pacey, flowmaster cb, pcm tune, what do you think 1/4 would be?
12-25-2007, 06:35 AM #62 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
I Bought some Texas speed heads with their double valve springs installed. They are good to .650 lift so you will be just fine with them. I would go with the Comp Cams pushrods. Changeing the springs will be a pain in the ass and you will need some special tools and an air comperssor. I'll try to find you a link to help in the cam and spring install and I'll post it later.
I live in Colorado so for your 1/4 mile time I couldnt tell you because we are close to a second slower than at sea level. I would guess you will be in the low to mid 12's? as a guess.
12-25-2007, 06:42 AM #72 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
Here is a very good install guide for a cam and spring swap. http://www.ls1howto.com/index.php?article=23
12-31-2007, 10:34 AM #8Member
- Feb 2007
- omaha, ne
red- 1998 camaro z28
I have some comp cam chromolly rods and they work great. The springs shouldnt be bad ull need a vavle spring tool to compress the spring to get it off. Also u might want to do some more valvetrain upgrades like ls7 lifters oil pump, atleast an ls2 timing chain texas speed is who i called they can give u some good deals.
Wtb pushrods
By jking78 in forum Parts Wanted / TradeReplies: 7Last Post: 11-02-2014, 06:04 AM -
Need new pushrods?
By shaggsm3ls1 in forum Internal EngineReplies: 6Last Post: 11-14-2008, 08:09 AM -
WTB pushrods
By SLDWS6 in forum Parts Wanted / TradeReplies: 0Last Post: 10-11-2007, 08:54 PM -
z06 cam, which pushrods to use???
By SSmoky01 in forum Internal EngineReplies: 4Last Post: 03-25-2007, 03:48 PM -
6.0 vs 5.7 ls1 pushrods
By blue99ta in forum Internal EngineReplies: 1Last Post: 09-25-2006, 04:10 PM
