12-23-2007, 05:20 PM #1Senior Member
- Dec 2006
- Deltona, FL
Sebring Silver Metalic- 2002 Camaro Z28
Add Wires To Factory Harness Connector?
Has any one ever added wires to a GM factor wire harness connector?
I'm trying to add the radio controls for the steering wheel. I beleive I am missing the needed wires at the back of the radio. I was thinking about trying to see if I could add / run a set of wires.
This would require me to add a set of wires to the factory wire harness connector.
Ever been done?
Any tricks?
Thanks
kool-aide
12-24-2007, 09:28 PM #2
Im sure its not too difficult, although i havent personaly done it, your best bet is to either get a wiring diagram or try to find someone that has a Factory instailed radio control's and just copy the wiring.
Make sure you disconnect the battery and have a few extra fuses on hand just incase.
12-25-2007, 09:05 AM #3Senior Member
- Dec 2006
- Deltona, FL
lol...yeah extra fuses...good idea thanks
12-26-2007, 12:43 PM #4Senior Member
- Feb 2006
- Orange County, NY
The only problem I would think is getting the connectors that plug in the harness. I know some auto stores have some, but not the ones you might need.
12-26-2007, 04:04 PM #5Senior Member
- Dec 2006
- Deltona, FL
I opted for a set of male and female d-sub pin connectors. they are the perfect size. I test fitted a sinlge wire and I was amazed. now I am still searching for the proper pin outs for the four wires. I know one will be ground, one will be power, and one will be illumination, and the last one should be radio control. One big question, do they all go into the rear radio harness? all the diagrams I have seen so far only show one pin out, the radio control. That leaves me with three wires to find a home.
01-02-2008, 11:47 AM #6Senior Member
- Dec 2006
- Deltona, FL
well i am done
i added to this thread on how i made out on adding steering wheel radio controls and a new fuse box circuit thingy
http://www.ls1.com/forums/showthread.php?t=70006
it was a ton of fun, even in the freeze FL winter weather.
oh, and thanks to all and all that helped, it was smooth sailing once i got the parts
Help: Ripped 3 wires out of a plugin connector above the starter
By Red8 in forum General HelpReplies: 3Last Post: 03-07-2017, 01:22 PM -
Trans Am Headlight harness connector
By transam_00 in forum Stereo and ElectronicsReplies: 10Last Post: 03-13-2010, 02:57 PM -
Factory Stereo Harness
By Spikito in forum Parts Wanted / TradeReplies: 1Last Post: 03-06-2010, 11:04 AM -
Wanted: Ignition Harness Connectors and TCS Connector
By 6speedTAthistime in forum Parts Wanted / TradeReplies: 4Last Post: 11-04-2009, 02:52 PM -
What wires on back of factory cd player do what? (installing deck)
By Mike Hawk in forum Stereo and ElectronicsReplies: 1Last Post: 02-17-2006, 02:08 AM
