Results 1 to 16 of 16
    Senior Member kool-aide's Avatar
    Deltona, FL
    Sebring Silver Metalic
    2002 Camaro Z28
    Help adding steering wheel w/ radio controls?
    I'm posting here to try and attract more viewers.
    I recently replaced my 99 A4 steering column and wheel with a M6 steering wheel and column from an 02 that has the steering wheel radio controls.
    I put every back together and noticed I could not find a place to plug the grey steering wheel radio control wire under the dash? If my camaro didn't have the this option am I hosed or just blind?
    BTW it doesn't seem as if the steering column has anything to do with this. The radio controls are fed by an extra wire set, grey, tha just runs the column with the rest of the pretty colors. I just wish I could figure out were it plugs in under the dash
    thanks
    kool-aide
    Retired Outlaw Sum Bitch
    What voltage is the gray wire? Is it normally open or closed?
    Deltona, FL
    2002 Camaro Z28
    dunno, how do I get voltage with no source, that is the question.
    Sarge, I have a plug from the steering wheel, multiple wires in grey plastic sheeth (sp ?). I'm looking for the other end, the side that would provide power and possible the end route to the radio.
    does any of that make sense?
    picture a line running from behind the air bag down the column to empty air, it needs to find a home...
    I still have this bad feeling I am screwed.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    have you pulled the radio to make sure there is a plug for the controls yet?
    Deltona, FL
    2002 Camaro Z28
    not yet, how do you pull the radio?
    You are going to need to marry each wire with its corresponding wire....make a custom harness....because that is exactly what you are doing...a custom harness...
    Deltona, FL
    2002 Camaro Z28
    I figured that.
    Any one know the easiest way to pull the radio?
    I figure I can match the wires from the radio to the plug by making a custom set of wires.
    Any one know what the pin outs are on the radio harness?
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Yank the trim piece off that is around the radio & AC controls.....pull the switches that may be attached & you'll see two bolts holding it in.
    Should take you five minutes including getting the nutdriver
    Deltona, FL
    2002 Camaro Z28
    thanks, should i disconnect the neg bat cable?
    Deltona, FL
    2002 Camaro Z28
    here is a pic of the radio rear wiring
    http://www.cardomain.com/ride/2954870/1
    here is my attempt at the wiring colors
    Red Connector, near antena
    Green
    Black White Stripe
    Brown White Stripe
    Green White Stripe
    Silver Cable ?
    Bigger Connector, black, lots of wires
    Top Row
    Grey ?
    Biege
    Green
    Light Green
    Brown?
    Grey ?
    Light Yellow
    Orange
    Bottom Row
    5 empty spots
    Green White Stripe
    Light Blue
    Blue
    Light Yellow
    Brown
    I have a feeling the radio controls are supposed to be in that empty row of five?
    United States Marine Kamauxx's Avatar
    Kansas City, MO
    Blazen Orange Metallic
    2006 GTO
    It may be easier for you to find a radio from a 02 and switch it out. Or at least switch harnesses. Just an idea.
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by kool-aide View Post
    Bottom Row
    5 empty spots
    Green White Stripe
    Light Blue
    Blue
    Light Yellow
    Brown
    I think you may be right champ.....I'll dig around & see if I can find some info
    Had my radio out today....I have controls in my wheel.....I do have a plug in that hole of five
    Here's a pic of he big plug
    Can't find a pic of the bottom 5
    I would suggest clipping one from a salvage yard car & trying a splice into it from your plug on the column.....I'll keep looking fo more info though
    Deltona, FL
    2002 Camaro Z28
    thanks, I appreciate it.
    Unfortunately my salvage yards never have f-bodies in them, wierd. They are very hot items and rare to come by. In the morning I'm going to stare at it for awhile and see if there is a way to pop fresh wire in there and keep it snug.
    any one know what gauge wire is used? I'm guess 20 ga solid wire?
    thanks
    Deltona, FL
    2002 Camaro Z28
    hah, rbob93 I just realized you are in Daytona. I guess you know what the local salvage yards are like. I went to that LQK on ISB looking for parts. I didn't want to waste my time since they don't track inventory and couldn't recall any 93-02s in the yard.
    I would prefer to try and slip new wire in before hacking on harneses and stuff. Heck if I was pulling from the bone yard I would take my big hammer, saw, and gut the whole wiring out of the donor. I real massacre surgeon, lol..
    Deltona, FL
    2002 Camaro Z28
    well i am done
    i added to this thread on how i made out on adding steering wheel radio controls and a new fuse box circuit thingy
    http://www.ls1.com/forums/showthread.php?t=70006
    it was a ton of fun, even in the freeze FL winter weather.
    Deltona, FL
    2002 Camaro Z28
    oh, and thanks to all and all that helped, it was smooth sailing once i got the parts
  1. Wanted: Camaro steering wheel radio controls
    By KMdef9 in forum Parts Wanted / Trade
    Last Post: 03-22-2012, 08:47 AM
  2. For Sale: 98-02 Steering wheel with radio Controls
    By Crimson Sin in forum Parts For Sale / Trade
    Last Post: 10-28-2010, 09:03 AM
  3. steering wheel with radio controls
    By ss6718 in forum Stereo and Electronics
    Last Post: 05-29-2008, 07:52 AM
  4. Steering wheel radio controls for 99 T/A
    By blackTA6585 in forum Stereo and Electronics
    Last Post: 09-28-2006, 08:04 PM
  5. Steering wheel radio controls for 99 T/A
    By blackTA6585 in forum General Help
    Last Post: 01-06-2006, 02:17 PM
