08-12-2005, 02:43 PM #1
some crane shaft mount rocker spy photos
while i was vinci today, i had the opportunity to sneak some pics of the developmental vinci/crane shaft mount rockers. from what i can tell, these rocekrs mount 2 per stand and are held down by three bolts. the stand is bolted to the head. then the shaft rockers are bolted to the stand. some major modification to the heads will be needed. these rockers, once available, will come in ranges from 1.7:1 to 2.0:1 ratios. these are for real high end racers. they are also fabricating a 1" valve cover spacer as well. vinci has fitted them to a set of AFR 205 heads to go on their PROJECT C6 car. so, here's the pics and enjoy!!!
08-12-2005, 08:39 PM #2Jesus died to save you!
- North Olmsted, OH
Navy Blue Metallic- 2000 Camaro Z28
Nice! BTW that is some big ass valve cover spacer!!!
08-12-2005, 08:40 PM #3
08-29-2005, 10:14 PM #4Moo cow f**k milk
- New Mexico...from Kansas City
Black- 2001 Camaro Z28
Looks tits!!! Wonder how much they'll cost.
09-27-2005, 11:48 AM #5notbobGuest
I saw these for sale on ws6project... anyone used them yet? whats the advantage?
09-27-2005, 01:17 PM #6Rhino21149Guest
What do they cost? They look alot like the Jesel Pro series but I hope they cost a lot less.
I've bought three sets for various engines : a Hornet set from Ligenfelter for about $800, and two different Jesel series (one adjustable, one not) for about $1300 and $1600.
11-24-2005, 08:46 PM #7
still experimental at this point. sometime next year for ls motors public release.
11-24-2005, 10:50 PM #8We'll be back...
- THE SWAMP
03-14-2006, 06:24 PM #9
those rockers are a work of art! i bet they will be expinsive as hell though...
03-14-2006, 06:25 PM #10
from what i've read, they are going to be under $1000.00 . you'll still need to buy the valve cover spacers.
03-17-2006, 08:48 PM #11ls1tech director
- Santa Clarita, CA
laser red- 1994 Mustang GT
i believe tony mamo told me they were gonna be a bit more. at any rate, i saw his and there fucking pimp, and worth were worth 10hp over his old HS (i believe) rockers.
Originally Posted by mrr23
03-18-2006, 10:57 AM #12
he had the vinci/crane 1.7 accelerated lift rockers before.
here's a graph of vinci C6 project car with the 1.8 accelerated lift rockers.
here's the graph with the 1.7 shaft mount rockers
Comp Cams Shaft Mount 1.7 Rocker Arms
By Nasty TA in forum Parts For Sale / TradeReplies: 2Last Post: 02-06-2012, 02:36 PM -
LS1 Shaft Mount Rocker Arms
By Nasty TA in forum Parts For Sale / TradeReplies: 3Last Post: 10-28-2008, 07:24 AM -
crane cam/rocker arm
By emotionalpiracy in forum Internal EngineReplies: 0Last Post: 09-15-2008, 07:39 AM -
By mrr23 in forum Internal EngineReplies: 4Last Post: 03-15-2007, 08:54 PM -
Yella Terra LS1 Shaft-Mount Rocker Arms, 1.7 Ratio
By CLHaka in forum Parts For Sale / TradeReplies: 2Last Post: 05-13-2006, 08:00 AM
