    Portland, IN
    1998 Camaro SS
    Quick Header Question.
    Just bought some Pacesetters and a Vinci tuner last night. My question is do I even need to mess with the O2 extensions and the back O2 sensors or can I just tune them out?
    Bragg NC
    Met. Sunset Orange
    01 SS
    The 02 extensions will be needed to connect the front two sensors. Although you will not have use for the rear 02's since they tell the computer that your cats are working.
    You can tune out the rear 02's with no issues but you do need to keep your front two intact and operational.
    J
    Portland, IN
    1998 Camaro SS
    Would I be better off buyin o2 extensions or usin the ones provided by Pacesetter?
    Thanks for the help.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Personaly i wouldnt reccomend anyone use those Bs extension deals that pacesetter sends out. Some people have luck and some dont.
    I would pick up some pre-made extensions, from one of our sponsers and do it the right way. Also dont use there paper gaskets, use the gm metal ones.
    J
    Portland, IN
    1998 Camaro SS
    I'm gonna take my manifolds off before the headers get here and check out my stock gaskets 1st if they're ok I'll reuse them.
    With all the money I just spent I think I'll try the supplied extensions 1st, if they don't work I can always get some new ones.
    Thanks again.
    Western Maryland LS1's
    Maryland
    1999 Camaro SS
    I'm Stupid
    whats a vinci tuner?
    old timer blue02Z's Avatar
    2002 Z28
    take my advice, dont reuse the header gaskets, they might work and might not, why take the chance on reduing all that, spend the $40. the vinci tuner will not clear rear o2's. just get the sims.
    ps. the vinci tuner is a handheld tuner that has 7 preset tunes for your engine. kinda like a hypertech but LOADS better
    Member 98ls1blackbird's Avatar
    Jenison, Mi
    1998 Trans am
    Another option instead of o2 extensions is the corvette 02's they have a longer pigtail and do not need an extension. Chances are real good that you will have to replace them anyway, mine threw a code for slow switching.
    98 Trans Am, A4, 3.73, 3200 Vigilante, LCA's, reloc brackets, sfc's, panhard bar, adjustable torque arm, XS long tube headers, ORY, SLP CNC ported heads and all the free mods tuned with EFILive.
    Best 1/4 et 12.53
    Best 1/4 mph 107.78
    Best 60' 1.71
    Quote Originally Posted by 98ls1blackbird View Post
    ding ding ding....we have a winner. I'm switching to bosch 13111's over the winter with the longer pig tails and to try and resolve my heater codes. I've read mixed results but I want to see for myself so I'm switching.
  1. Help: Header install tips quick
    By davidz28 in forum External Engine
    Last Post: 05-11-2011, 12:00 PM
  2. Quick header gain question
    By JwMonE99 in forum External Engine
    Last Post: 06-03-2008, 06:22 PM
  3. Quick header question
    By Daniel P. in forum External Engine
    Last Post: 04-20-2008, 03:33 PM
  4. quick question
    By eatsrice in forum Nitrous
    Last Post: 10-25-2007, 08:03 PM
  5. quick header install ?'s
    By JonB in forum External Engine
    Last Post: 01-08-2007, 03:50 AM
