Results 1 to 20 of 20
    Camp Lejeune, NC
    American Racing LT Questions!
    Hello,
    I'm in Iraq right now and can't get on to their site for info about their headers. I need to know if they come from LMP with or without EGR and whether or not they come with any hardware or accessories.
    What I will NEED (extension sizes included) to install. e.g. hangers, or anything else that will need to be purchased BEFORE the install so I can move through the install. Its my only vehicle and I'm going to have to pay for pretty limited shop time.
    Any info you have on what I will need will be greatly appreciated.
    Semper!
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by Kill98 View Post
    Hello,
    Semper!
    E.G. Hanger?
    Member CJREX's Avatar
    GA
    Gone:2001 Camaro SS #4846
    E.G. = example given.
    He wants to know about any extraneous BS that would require him to run all over town looking for it, so he can get it up front and spare the hassle.
    God Bless our Troops
    Camp Lejeune, NC
    as in "example"
    I need to know if I will need extra hangers for the Y, whether or not they come with 02 bungs on the Y, whether or not they have EGR provisions.
    I hate to come here with questions but I can't find a site with real info on them because as I said their site won't load for me here!
    Thanks for the help!
    Camp Lejeune, NC
    No one knows whether the headers LMP offers has or doesn't have EGR provisons or what length O2 extensions I'll need?
    Matt
    West Chester PA
    1998 Trans Am Ws6// LS6
    I got my ARH's for New Era Performance not LMP, they had the best price. I was also very impressed, they called me the next day just to make sure they had my order right. I got the street legal version ones, Catted Y-pipe, Air injection, EGR, and they came with O2 extensions. They also came with clamps, and gaskets. The only thing I had to reuse was the bolts that came off the stock manifolds, the flanges are the same size so that works perfect. They only thing you might need is a conversion pipe to attach it to your cat-back system.
    BTW their Header kit fits perfect and you'll have a ton of ground clearance
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    Steve82ta what was your HP and TQ gain?? with tune and without..
    Rochester
    99 Camaro
    We generally see 15-20 rwhp with catted y-pipe before tuning , and 20-25 rwhp with tuning . O/R ypipe will net you around another 3-4 rwhp with a bolt on car , and probably 5-8 on a cam/head power adder car . The ARH cats are the highest flowing I have seen , the only system that will trip the cat code almost imediately on most cars we have installed them on because they are so high flow . Make sure your tuner turns off the codes or you will most likely be back if you are using these headers because these cats are close to not having cats !!
    Mike
    www.neweraperformanceparts.com
    [email protected]
    585-865-1832
    Feb 2007
    FairField, CA
    Right on man..
    West Chester PA
    WARP211,
    Sorry I don't have any before or after dyno number for you, I put the headers on while doing the Caddy LS6 Engine swap, Its cake to do with the engine out of the car.
    I still need to get the car tuned, haven't had a chance to get around to it so I can't help you out with numbers there. Althought the car runs fine with the stock tune, although Im sure it could perform a lot better.
    Plus like I said I went from a stock engine to the 405 Hp Z06 motor, added the ls6 intake, along with the American Racing headers.
    Mike is also correct about their high flow cats. They Will trip your catalyst efficency monitor and set the check engine light eventually. I've talked already New Era about it, and they suggested I get it tuned.
    Not to hijack this thread but, Mike can you guys at New Era perform a tune without the car, IE me sending you the PCM for a couple of days? My setup isn't too radical, Ls6 engine from intake to pan, its the +02 one, so it has the biggger camshaft, and like I said I added the ARH's. My T/A currently has the stock '98 tune in it.
    Steve
    Feb 2007
    FairField, CA
    Right on steve83ta.. for the info...
    Feb 2007
    FairField, CA
    does anyone know the power gains from a y-setup with headers and full exhust .. let say ARH Headers and Y-pipe with cat back(20-25HP)... compared to a True dual exhust.. Whats the power gain difference.. Same Headers just different setup.. going from a Y-setup to a True dual.. like what 5-10hp difference..
    Rochester
    99 Camaro
    Sorry , I don't do mail order tuning , gotta bring it up here man .
    Here is a true dyno graph before and after results we did on a completely stock 02 SS with an auto transmission . All testing done within 24 hours .
    Run 1 = Stock
    Run 2 = American Racing headers with high flow cats installed
    Run 4 = Custom tuned by me on the dyno (the graph cut out for a split second from the rpm pick up , but you can see the results)
    Mike
    [email protected]
    585-865-1832
    Camp Lejeune, NC
    Mike,
    Do your ARH headers with ORY come with EGR fittings? Or are they full race style?
    I also saw that supposedly they are sent out with 02 extensions and gaskets?
    Thanks
    Canby, Oregon
    1999 Camaro SS-M6 #1775
    They ARH Headers I have are the 98-99 style with the all the EGR fittings, with all the o2 extensions, brackets, gaskets and bolts, with the ORY. the ground clearance is superb and the fitment quality is exellent, i would recommend them to anyone.
    I just ordered the Header and the ORY pipe and everything else was included with it, i did not need to purchase anything extra.
    One of these days il get it on the dyno and post the results.
    12.6 at 112
    Rochester
    99 Camaro
    You can get them with or without , you just need to specify this when you order them . They come with everything you need for complete installation .
    Mike
    Camp Lejeune, NC
    Also what is this about possibly needing a conversion pipe to connect to catback? I have magnaflow and if I end up buying a new car will either go with magnaflow again or GMMG.
    Thanks!
    Rochester
    99 Camaro
    Neither of those will have a problem connecting up directly , I have never had an issue with any aftermarket catbacks .
    Mike
    West Chester PA
    [QUOTE=New Era Performance;1205837]Sorry , I don't do mail order tuning , gotta bring it up here man .
    Yeah Mike thats what I thought, But I figured it couldn't hurt to ask. Your a long way away from Philly.
    Thanks!
    I guess this must have been an isolated event for me. Like I said I have the ARH's long tube with the catted Y. (AND LOVE THEM, fit finish and ground clearance is like no other) The Catback on the car was not orginal. Its some piece of crap Flowmast system, that was on the car when I bought it, that I can't stand, and it wiill be gone when I get enough extra cash for the Corsa system.
    Steve
    West Chester PA
    I know this this thread is old and I'm bringing it back from the dead, but anyone considering a long tube header set-up go with American Racing Headers, and I highly suggest getting them from the guys at New Era Performance they are great!
    Like I said eairler in this thread I have their Long tube headers, with air injection and egr so I could retain emission legal status, because I live in one of "Those" states along with their high flow catted Y-Pipe.
    Its been almost 7 years now that I have had this system on my Trans Am and I've never had an issue with them. Not one cracked weld no leaks, not a problem, not one!
    Im mainly just updating this thread becuase of the cats. They are truely some of the highest flowing cats you can get for your car. You don't lose much if any hp or torque by using them.
    The only thing I disagree on is tuning out the rear O2 sensors, Ive been running them for like I said 7 years and never once had a problem with catalyst efficiency, never once had a code. They were never tuned out. So I highly suggest them.
  1. American Racing LT headers/ ORY Questions?
    By LETHALxLS1 in forum Camaro / SS
    Last Post: 07-13-2014, 02:47 PM
  2. Question: American Racing, TT2's
    By third_shift|studios in forum Wheels and Tires
    Last Post: 07-11-2011, 07:17 PM
  3. OBX or American Racing Headers?
    By xzaero0 in forum External Engine
    Last Post: 08-01-2007, 09:41 PM
  4. American racing rebels
    By homerunhtr21 in forum Wheels and Tires
    Last Post: 01-27-2007, 09:24 PM
  5. American Racing TTII's
    By austinWS6 in forum Wheels and Tires
    Last Post: 11-21-2006, 09:56 AM
