Thread: torquing pattern please help
12-14-2007, 05:16 PM #1Junior Member
- Jun 2007
- Ohio
black- 1995 camaro
i am putting my lt1 back together and i need to know the torquing pattern of the head bolts and the intake bolts as well as the ft/lbs or some where i might be able to find those specs.
Thanks
12-16-2007, 03:51 AM #2
Sent you a pm..
12-20-2007, 12:51 AM #3Junior Member
- Sep 2005
- Dallas Tx
hey morton, how are things coming along? i have not had the chance to start on mine yet. let me know what major problems you ran into that you did not expect.
12-22-2007, 10:01 AM #4Junior Member
- Jun 2007
- Ohio
black- 1995 camaro
i just finished it up yesterday it really was not to bad. the only problem i had was the headers. so if you are planing on putting on headers plan on disconnecting the steering shaft and taking off the starter. the biggest peice of advice i really have is make sure that you put it all back together the order it came off so you dont forget something then have to break it back down, also make sure you seal up the intake really well. i did not run into any stripped bolts or seized up bolts but they may be a problem you could have but other than that have a friend help you and plan on doing this for a while i worked on it for about 7+ hours a day for about 3 days so it takes a while. good luck though bud hope it goes well.
Issue torquing flywheel bolts....
By bad idea in forum Manual TransmissionReplies: 10Last Post: 08-25-2012, 10:14 PM -
Lug pattern
By RamAM02 in forum Wheels and TiresReplies: 1Last Post: 03-05-2011, 03:28 PM -
Question: Bolt Pattern
By amysboxers in forum Wheels and TiresReplies: 4Last Post: 02-25-2011, 11:04 AM -
lug pattern
By 20redbody00 in forum Wheels and TiresReplies: 1Last Post: 11-27-2009, 05:45 PM -
Torquing the lug nuts
By {FzS}BlacKMagicK in forum General HelpReplies: 13Last Post: 08-25-2007, 12:56 AM
