    Member Kup98ss's Avatar
    North Carolina
    2002 A4,WS6
    Will I have problems installing a CAT back on a WS6? 3" pipe.
    A regular TA has smaller than 3 inch pipes for exhaust, right?
    Since the WS6 already has 3 inch pipes will this cause any problems installing a CAT back? Or will the cat back pipe slip right over a 3 inch factory pipe.
    I've never heard any complaints about this, so I just thought I'd ask.
    Thanks.
    old timer blue02Z's Avatar
    2002 Z28
    the only difference from a regular t/a and a ws.6 is the hood, wheels, and i think shocks.
    identical exhaust setups for all ls1 f-bodys, so you will be fine
    2002 Z28 M6, Suncoast Creations ram air, port/polish TB w/ bypass and bumpstop, heater hose mod, stainless steel long tubes, ORY w/ dual cutouts, Magnaflow, BMR SFC, UMI Torque Arm, LS7 clutch w/ drill mod, Pro 5.0 w/ Lous short stick, MSD wires, 4.10s, good maintenancehttp://www.fquick.com/blue02z
    Canada eh
    99 TA
    Quote Originally Posted by blue02Z View Post
    wS6 Cars did have a different cat back actually, im not sure if it was wider than the reg t/a's though.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Quote Originally Posted by KyleLs1 View Post
    The I Pipe diameters are the same 2.75" the only real difference is a slightly less restrictive muffler and polished round tips.
    The `98 system had a single 3" exit pipe on the drivers side w/ a 3.5" tip
    this is the only factory WS6 system that flows better.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    2002 Z28
    Quote Originally Posted by 9T8W66 View Post
    that is what i was talking about-the i pipe, thanks for the backup mr encyclopedia
    North Carolina
    2002 A4,WS6
    So I will be fine then?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by Kup98ss View Post
    You are going to be installing a cat-back so you are eliminating the 2-3/4 intermediate pipe, so there will be no problem.
    North Carolina
    2002 A4,WS6
    That is what I was looking for. Thanks very much.
    Florida
    Balck
    2002 Z28
    YEP! Almost Exact exhaust from Z28/formulas and SS/WS6
    The ONLY difference from those 2 are that the tips are nice and polished and the muffler on the SS/WS6 are smaller... ever notice the nicer rumble from a SS over a Z28 OR a WS6 over a formy? I only notice the muffler sizes b/c my sister has a 02 WS6 and I installed SLP LM cat-backs on both of them. I'm thinking about putting her stock cat-back onto my 89 RS D.D. with my stock Z28 tips.
    The only problem I've ever heard of when installing cat-backs is sometimes on the 4inch systems... if you don't have the pipes angled correctly when going over the axle, you might get a clunck when going over bumps and dips in the road, though again, you could get that with any multi piece cat-baci i suppose...
  1. I'M BACK.....but with problems!
    By blackSS01 in forum Almost Anything Goes
    Last Post: 09-26-2009, 08:22 PM
  2. problems after installing sound system!!
    By supersport00 in forum Camaro / SS
    Last Post: 08-08-2008, 01:58 PM
  3. Replies: 0
    Last Post: 06-01-2007, 10:00 AM
  4. Replies: 1
    Last Post: 05-05-2007, 01:34 PM
  5. What wires on back of factory cd player do what? (installing deck)
    By Mike Hawk in forum Stereo and Electronics
    Last Post: 02-17-2006, 02:08 AM
