Results 1 to 15 of 15
    now greybat66
    bloomfield nj
    1998 trans am
    slp mass air flow sensor
    Just curious if the slp mass air flow sensor really made a big difference in horsepower and how much thank you.
    Junk.
    Stock MAF is good enough for 500 RWHP and more.
    SLP's isn't calibrated correctly for our cars. It will add a little HP, but only because it leans you out. In some cases enough to start pinging.
    Lowered, HID's, tinted.
    old timer blue02Z's Avatar
    2002 Z28
    i noticed a lil of a difference with mine, waste of money prolly
    silver2002Z
    Guest
    dont waste your cash
    caraholic ggino85's Avatar
    most miserable city in the US
    blue green chameleon
    i did NOT notice ANY!!! power gain with mine, the only thing i did notice was a major loss of low end power. all it does is lean the crap out of the motor, dont waste your money its JUNK!!!!!!!!!!
    Bragg NC
    Met. Sunset Orange
    01 SS
    Dont watste your time, the only gain you will see is Now your car will be throwing codes.
    J
    Member jag42420's Avatar
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    A new MAF requires a tune to work correctly. Between the cost of tuning and the MAF cost, any minimal gains would not be practical unless you're full bolt on with a cam and/or heads. As stated above, the general rule of thumb is that the stocker is good for up to 500HP.
    2002 WS6 Trans Am, A4, SLP lid, P&P TB, 3500 stall, 24K GVW tranny cooler, HPTuners, Pacesetter LTs, Bassani dual exhaust with 'x' crossover, coolant bypass, sealed airbox to hood.
    http://www.cardomain.com/id/jag42420
    in my Trans Am
    2000 Trans Am WS6
    Well I would agree and disagree. I have a tune and was running a stocker. About 6 months ago I switched to the Slp. I have no complaints. Was runnig a bit rich anyway(you could smell it) so it was good for me. I didnt feel a huge difference but the response is a bit better. Just my two sense. I think it depends on the mods you have etc, I think its worth it, but I agree that you would need a tune. If you are running mostly stock parts you def dont need it.
    Member Empatho's Avatar
    San Diego
    02 Z28
    well I have one on my car but I took it off today and put it away, Im going to put it back on the car when I get heads+cam
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Port the stocker and get a tune.
    Junior Member ChrisV 02 - Z28's Avatar
    Kentucky
    2002 Camaro Z28
    Are you talking about running rich at WOT, cause your fuel trims will bring you to stoich at part throttle.
    Either way you will have to tune for the maf to keep your trims inline
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Gave me lean codes until I removed it.
    Member jamessr's Avatar
    Newport News, VA
    2000 Trans AM
    Whoever had my TA before I bougth it removed the screen of the MAF. I did consider buying a new one but.... I decided just to clean the one I had.
    I'm glade I saved $200. I got all the HP I could expect from just general cleaning.
    just my .02
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    I don't know what everbody's deal is with the SLP Mass senor.. I installed the senor and haven't had anyproblems with it.. It never threw a code like some people say. All I have is SLP CAI and the Mass.. I put down 350TQ and 340 HP at the wheels.. It may have lean me out a little.. and if it does lean you out its not a bad thing as long as your no in the 15:1 range.. The factory tune already runs your car rich anywayz.. Maybe its just depens on where you live and the weather conditions.. also altitude also play a factor..
    Member craz1469's Avatar
    Aug 2006
    Near Houston
    2002 Camaro Z28
    I also have a SLP maf and have no problems with it what so ever. I bought it because my stocker was fudged up making be run very rich. It gave me a big gain just from fixing the proble 13.5 to 13.0s then 12.7s with better tires. I even sprayed a couple of bottle through the motor with a dry shot and never had it knock.
    12.8:1 is the ideal A/F radio for a N/A car. If it got up that high it would start to lean pop.
    Porting the stocker is the same as using the bigger LS6 maf. Its going to lean your motor out because your getting more air than the stock tune knows about.
  1. Question: Mass Air Flow Sensor?
    By flotty in forum External Engine
    Last Post: 09-23-2010, 06:36 PM
  2. WTB LT1 Mass Air Flow Sensor
    By camarolvr69 in forum Parts Wanted / Trade
    Last Post: 11-05-2007, 04:21 PM
  3. slp mass air flow sensor
    By darryl in forum General Help
    Last Post: 10-06-2006, 10:22 AM
  4. SLP Mass Air Flow Sensor
    By easyericvan in forum Parts For Sale / Trade
    Last Post: 04-17-2006, 07:03 PM
  5. FS: ECM and New Mass Air Flow Sensor
    By Sandragnx in forum Parts For Sale / Trade
    Last Post: 09-29-2005, 03:10 PM
