    Dubois, IL
    Copper
    2002 Trans Am
    Whats best clutch for supercharged LS1?
    I have a procharged 2002 Trans Am. I am having problems with going through clutches. I have been told that the master cylinders are a big problem. I have replaced everything but the master cylinder. My last clutch lasted me about 1500 miles. I was just wondering what kind of clutch has worked for everyone else. My car has 410 hp and tq at the wheels.
    Member 180ls1's Avatar
    San Diego (Poway)
    1998 Firebird Formula WS6
    you will want a twin disk clutch much smoother and more holding power.
    Local Bum TARZAN's Avatar
    Memphis Area
    Cobra, Z28, GN, F250
    Calling a twin disk clutch overkill for your car would be an understatement....
    "I am having problems with going through clutches. I have been told that the master cylinders are a big problem. I have replaced everything but the master cylinder."
    Why is this? I say replace the master cylinder with a nice aftermarket (Ram or McCleod), better units, AND adjustable....go ahead and replace the slave while you're at it to avoid any gremlins. When installing, make sure and BLEED BLEED BLEED that clutch system, not only to get out air, but also to get fresh fluid in it....
    What kinda clutches have you been frying? Honestly, with the power level you listed (that sadly seem kinda low) I'd say just go with an LS7 clutch/pp/flywheel combo....
    -Will
    Dubois, IL
    Copper
    2002 Trans Am
    What kind of number do you get out of your car. My car stock was only 283 rwhp.
    Dubois, IL
    Copper
    2002 Trans Am
    I see that you are running a Pro 5.0 Shifter. Can you tell a difference from the stock shifter?
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    which clutches have you tried? i got a Spec 3+ in my LT1 car and it has a supercharger, its been a good clutch so far to me. but it only has about 800 miles on it.
    95 WS6, 6 speed, FULL suspension, 9" spool, Vortech S/C HARD TOP!!!!!!!!!!!!!!
    99 Z28/SS Vert Triple Black, H/C
    Memphis Area
    sounds like you may be at elevation on a mustang dyno.....I spoke before I asked lol...
    I've got a Hurst shifter, and so far I'm pleased with it.
    -Will
  1. Whats up with my trans/clutch?
    By Y2K_CAMARO in forum Manual Transmission
    Last Post: 09-07-2009, 12:25 PM
  2. Whats A Good Clutch
    By joshiceman15 in forum Manual Transmission
    Last Post: 07-22-2007, 05:17 PM
  3. whats the best clutch kit?
    By miller456 in forum Manual Transmission
    Last Post: 03-04-2007, 06:41 PM
  4. Whats The Best Clutch For A 98z8?
    By miller456 in forum Drivetrain
    Last Post: 02-21-2007, 07:49 PM
  5. whats wrong with my New Clutch
    By screamin chicken in forum Manual Transmission
    Last Post: 03-30-2006, 05:53 PM
