View Poll Results: Charger install on 98 T/A
Voters
19. You may not vote on this poll
  • Procharger D1sc
    7 36.84%
  • MagnaCharger maguson m112
    5 26.32%
  • Vortech
    2 10.53%
  • STs
    5 26.32%
    Junior Member 98_Ws6_scooter's Avatar
    Southwest Va
    1998 Trans am A4 Ws7
    If you guys had a 98 A4 T/A with 91,000 miles with mods in sig and was wanting to do a procharger or magnacharger set up what supporting mods would you go with???
    super charger?
    intake?
    injectors?
    throttle Body?
    Tune? Where?
    24219 Zip
    Just wanting some opinions thanks.....
    And what about Speed density Tunning? Is it a have to?? Do i have to do away with Maf????
    10 sec street car, Full weight. D1sc,tsp 402,12 bolt,rpm lvl 6 4l60e
    doesn'tplaywellwithothers superchargedblackgto's Avatar
    Mayberry....(Indiana)
    2004 GTO
    Quote Originally Posted by 98_Ws6_scooter View Post
    super charger?
    intake?
    injectors?
    throttle Body?
    Tune? Where?
    24219 Zip
    No, you can keep the MAF on a Maggie, I did a 90mm TB, you can keep stock if you want, It's up to you. Maggie comes with the injectors, I believe thay are 42#er'2, I also had them customize the screws, but you can buy the stock setup. I had to have a custom hood made. Just to get the 90mm TB to fit with the maggie, however IDK about the ws6, 2 different cars. Anything you go with you need supporting mods, like SFC's, and such but on your setup, I'd go with procharger or turbo, just because of the hood issues and such.......Good luck,
    Brad
    '04 gto M6 slp ceramic coated headers,B&m sport shifter,harrop cover,3.5"aluminum BMR driveshaft, BMR axle stubs, BMR Half shafts, BMR SFC's, loudmouth2 exaust,90mm FAST T/B,Magancharger(high helix upgrade)......other misc. suspension,Cross drilled, slotted rotors. Meth Kit, spraying @ 3psi and up
    Deltona, FL
    1998 Camaro Z28
    Procharger. That is what I did, and it is great!
    San DEEEE Eggo
    teal
    99 Z28 with an SS complex
    i'd go with the maggie too, from that list. What kind of power are you looking for.
    Member LUGNUTT's Avatar
    maryland
    1999 WS6 Trans am
    If you go procharger make sure you at least get the 8 rib belt setup.
    Member Tman's Avatar
    Woodstock, GA
    2000 WS6
    I optioned for Vortech.. Why ? well I have one !
    Deltona, FL
    1998 Camaro Z28
    Quote Originally Posted by LUGNUTT View Post
    If you are going 8+psi.....
  1. LS1 Magna Charger TVS Supercharger Install - Magni
    Last Post: 12-08-2008, 07:20 PM
  2. New Charger ?s
    By MaxPlusTen in forum Almost Anything Goes
    Last Post: 04-21-2008, 07:42 AM
  3. Charger install on 98 T/A
    By 98_Ws6_scooter in forum Forced Induction
    Last Post: 12-10-2007, 08:31 PM
  4. Shop for Pro Charger install?
    By FastAl in forum Rocky Mountain Members
    Last Post: 08-27-2007, 02:38 PM
  5. SRT-8 Charger and SRT-4
    By zero_proto in forum Kill Stories
    Last Post: 01-29-2007, 06:28 PM
