Results 1 to 20 of 25
Thread: Wire hide mod
12-07-2007, 08:42 AM #1
Wire hide mod
Has anyone did this? Hiding the wire harness on the passenger side fender. I saw this a few years back. Is there a guide somewhere?
12-07-2007, 08:54 AM #2Just me
- Nov 2006
- Broken Arrow, OK
http://www.lswon.com/2005/01/25/wire-mod/
Done it a few times myself.
12-07-2007, 09:13 AM #3
linkie no workie
I have looked on google so much and still found nothing myself
12-07-2007, 09:24 AM #4
12-07-2007, 11:43 AM #5
anybody else have any links?
12-07-2007, 12:53 PM #6LS1 powered LT1 Z28
- May 2007
- Amarillo, Texas
Polo Green Metallic- 1995 Camaro Z28
All you do is make a 2" by 3/4" hole by the pcm to run the wires into and connect them underneath the fenderwell. I will post up a few pics real quick
12-07-2007, 01:04 PM #7
Here is a couple pics
http://www.fquick.com/mnypitZ
98 Z28 a little here and a little there
03 Saab 9-5 ARC
80 Triumph TR7
12-07-2007, 01:55 PM #8LS1 powered LT1 Z28
- May 2007
- Amarillo, Texas
Thanks man I hadnt had time to get mine
12-07-2007, 05:18 PM #9
http://www.camarohighway.com/hidden_hood_cable_mod.htm
Some others you might consider, ...
http://www.xse.com/leres/ss/drl.html
Can't find my !wire mod link yet, ...
12-11-2007, 11:48 PM #10
12-12-2007, 05:29 AM #11
12-12-2007, 05:55 AM #12
saw it on ls1tech and always wanted to get rid of the wires that run along the passenger fenderwell under the hood. took about 30 minutes. didn't have my camera to show how to do it, but you'll get the jist of it.
remove the passenger tire and inner plastic fenderwell. cut a rectangular hole and separate the wires from their connectors and push through. the ones that come out from the nose area will go through the hole that's already there by the headlights in the fender.
move the ground wire down below the fender by the battery. there was a hole there already. just had to thread the lug into it.
and here's how it looks
12-12-2007, 07:40 AM #13
My buddy used nylon push pins to fill the holes he told me.
04-06-2009, 04:22 PM #14
Okay. I'm getting ready to do this mod, for both sides. Just to make sure, I'm only making holes big enough to slip the wire looms/air hose through the metal work. Does this weaken the shock tower sheet metal in any way?
04-06-2009, 04:27 PM #15
04-06-2009, 05:27 PM #16Middle Name=Awsome Sauce!
- Jul 2008
- La Puente, CA / Whittier, CA
Red-ish- 1992 Z28
IS this same thing doable on an LT1? The wiring is a tad differant.
04-06-2009, 05:41 PM #17
you can also do this on the driver's side to hide the hood latch cable - though you only need to drill a 3/4" hole. speaking of which, i was able to get away with just drilling a 1 3/4" hole on the passenger's side. just try to get the hole as close to the hood strut mount as you can.
i would also suggest not moving the ground mount to where mrr23 suggests (sorry bro). that hole is used to hold the plastic inner fender in place. i created a new hole to use.
04-06-2009, 05:59 PM #18
04-06-2009, 06:39 PM #19TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
something about moving these scares me. i dont know why
i guess im just a chicken
04-07-2009, 02:52 AM #20
My local club is getting together in a couple weeks to do multiple mods. A local car repair shop is lending us the space to do it.
Here is another link to LS1 Tech on the mod:
http://www.ls1tech.com/forums/appear...al-inside.html
Help: vacuum line broke when doing wire hide mod
By godless-phoenix in forum General HelpReplies: 9Last Post: 03-12-2012, 07:17 AM -
Battling Cancer and the Wire/Hood Release Hide Mod
By ls1camino in forum Appearance SectionReplies: 15Last Post: 06-05-2009, 05:05 AM -
how do you hide the wire harness?
By bobbert350 in forum Appearance SectionReplies: 4Last Post: 07-31-2007, 08:05 PM -
How To Hide
By blackbird02 in forum NitrousReplies: 9Last Post: 04-02-2006, 04:10 PM -
best way to hide solenoids???
By shift_down in forum NitrousReplies: 6Last Post: 03-01-2006, 11:02 PM
