    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    60' and the aluminum ds
    what is your best 60' on the factory aluminum drive shaft?
    i have been cutting 1.74 with my steel and have decided to got aluminum for weight savings, plus it eliminated all vibrations i had, won't be able to go to the track until it opens in the spring, but will like to have some piece of mind if someone else is running in the 1.60 range with an auto and not having any problems, i have seen them break on m6 cars but that was when they dump the clutch at 5,000, my auto isn't near that hard on the drive line, even with my 2800 fuddle
    please post, 60' times, gear, stall, tire size, m6 or a4
    thanks
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    My best 60' is a 1.34 / 4.10 gear, 4600 stall, 28" tire A4 ( stock aluminum shaft / moser rear )
    Washington MO
    sebring silver
    2000 z28
    thats a damn good 60'. I think i'm in the clear, hopefully i can get in the 1.69 range next spring.
    since the 1.74 time i removed about 90lbs, 8lbs of that being the drive shaft, fixed shift points from 6,500 to 6,200 on the 2-3 shift, relocated the battery to the trunk, and still plan on the lighter k-member and fiberglass hood, thats another 50 lbs off the nose.
    maybe an 11.99 if the air is right
    2000 auto camaro
    13.54 @ 104 2.049 60' stock 2.73
    12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
    11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
    Feb 2007
    St Thomas, PA
    Yea, That's my origonal driveshaft that came with the car ! You will be OK !!!
    P.S. I don't beat on mine !!! LOL !!!
    1.67 bogging.
    M6 car
    East Peoria, Il
    1998 Pontiac Trans Am WS6
    1.49 stock rearend(3.23 gears), 3600 stall, stock driveshaft.
    Member Empatho's Avatar
    San Diego
    02 Z28
    Quote Originally Posted by sbpower72 View Post
    to your stock rear end
    2002 Z28 Auto (3.23 gears)
    Mods
    Lid, UD pulley, Shift Kit, 160 Thermo, Y-pipe, Panhard, TB bypass, Bellow, K&N, Strut Brace, Flowmaster, weight reduction.
    central, illinois
    pewter
    2000 trans am
    1.53 with an m6 in my old camaro with a low 11 sec pass on my stock aluminum driveshaft.
    Junior Member ragenz28's Avatar
    Jan 2008
    Port Hueneme, CA
    1998 Z28 Camaro
    1.30 so far on an Inland Empire Driveshaft.
  1. Help! Aluminum 5.3
    By rocksolid in forum General Help
    Last Post: 10-10-2009, 01:27 PM
  2. will this Aluminum Driveshaft fit?
    By QuicSS in forum Drivetrain
    Last Post: 03-11-2009, 10:30 AM
  3. Question: Aluminum frames?
    By TOPORANGER in forum Corvette
    Last Post: 03-06-2009, 04:03 PM
  4. wtb aluminum driveshaft
    By 89 406 6speed in forum Parts Wanted / Trade
    Last Post: 06-18-2007, 06:50 PM
  5. Aluminum Balancer
    By FuzzyMcGee in forum External Engine
    Last Post: 02-21-2007, 08:29 AM
