Results 1 to 3 of 3
Thread: Gear Ratios?
    Dreaming of an LS1 senior gomez's Avatar
    SC
    Teal
    91 teg (stock,notmodding)
    Question Gear Ratios?
    ok so as i continue my never ending quest of knowlege about well cars basicly, ive come across gear rations such as 3.43 or 3.75 or somethin. what exactly does all that mean? im pretty decent at math so if theres like a formula or some way to remember that would work too. thanks!
    Silver SS in Germany
    Guest
    A 3.42 rear gear ratio: It will take the driveshaft 3.42 times to rotate before the tires will rotate once. The lower the number the longer you will have between gear shifts and the higher your top speed will be. A higher number will help you accelerate quicker but will have a lower top speed.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    At the very top of this forum there is a thread called REAR END FAQ. Your question is answered there....
  1. Rear End and Gear Ratios
    By DaddysZ28 in forum Drivetrain
    Last Post: 05-04-2010, 06:48 AM
  2. 2002 ss gear ratios
    By rapidride2 in forum Camaro / SS
    Last Post: 06-17-2007, 09:21 AM
  3. 2006 GTO Gear Ratios
    By Tom 06 GTO in forum Drivetrain
    Last Post: 08-20-2006, 03:15 PM
  4. gear ratios
    By ls1colorado in forum Drivetrain
    Last Post: 07-08-2006, 11:26 PM
