Results 1 to 18 of 18
Thread: Chirping
    Junior Member Ls1fury's Avatar
    Cali
    Midnight blue
    1999 z28
    Chirping
    my engines makeing a chirping sound...its not the belts.... its comeing towards the back .......but it only starts getting noisey after the car warms up....any body had a simaler problem....
    Ben
    Guest
    Mine is doing the same thing.. Anyone?
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    mine makes a clicking noise that almost sounds like the injectors but it doesnt really get worse
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    clicking
    i have the clicking noise 2. The clickig noise is the valve train. its not as bad on the 01-02 LS1 as it is on the earlyer years.
    texas
    2002 ss camaro
    my old '01 z28 i used to own did something like that. the dealership replaced the belt. if not that then it could be the belt tensioner. good luck!
    Member 98Z-28Camaro's Avatar
    Oklahoma City
    1998 Z-28 Camaro
    I also have the clicking noise on my 98 Z but it nevers gets worse and I only hear it after I run it hard or when it is warming up.
    guys with clinking noises, do you have M6's? your throw-out bearing could be shot in the clutch.
    squeeks in the back of the engine? hmmm...how often do you get it? is it when it revs? while in N or in gears? or while clutch is engaged/disengaged. Does it increas with RPMs?
    Oklahoma City
    1998 Z-28 Camaro
    Respond to Third_shiftlstudios I have the clicking noise and no. I have an a4
    Dec 2004
    SS: NBM, tan top
    wouldnt it be the throw out bearing only if you had the clutch pedal depressed?
    aside i dont think its that, that would be louder i think
    Aug 2006
    Louisiana
    RED
    2002 Pontiac Firehawk
    Quote Originally Posted by 98Z-28Camaro View Post
    Have you had the pulleys looked at to see if the bearings are worn out in any of them. My '02 Firehawk was doing the same thing until Pontiac replaced one pulley (cannot recall which pulley they replaced but could if needed) in the system which resolved the chirping noise but now my LS1 throws my belt out of the grooves when given hard gas. So I need to replace the harmonic balancer (underdrive pulley). So again my LS1 is back to chirping b/c the belt is stretched from being thrown. This is from SLPonline regarding the LS1 problem with the belt slippage:
    SLP's new 25% underdrive balancer for LS1 F-Bodies incorporates a number of high-quality features you won't find on any other aftermarket unit. Chief among them are a pair of extra-tall belt-retention walls that eliminate the belt-slippage issues endemic to other LS1 balancers (see photo). Other unique design strengths include 100% steel construction (other brands use steel and aluminum), integral timing marks, and built-in puller-mounting threads. Includes a new balancer bolt and detailed installation instructions.
    Oklahoma City
    1998 Z-28 Camaro
    I don't know what brand of underdrive pulley I have because it was on when I bought the car but I bet it ain't SLP. I will have to try that, I will also have to check all my bearings in the pulleys and isn't the throwing of the belt the tensioner being wore out?
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    i had the same clicking nose too and im in a a4 97 trans am. never figured it out. i put my new motor in and it was gone. i totally forgot about it until this post. but i dont know why it would have stopped because of a new motor, i did all the work myself and i didnt notice anything weired
    Canada eh
    99 TA
    Quote Originally Posted by ss~zoso~ss View Post
    i think so... when mine started to go, everytime the pedal was depressed it made a horrible noise
    Houston, TX
    2002 Camaro SS
    Im havin the same problem, with the noise but my 02 SS only has 31,000 miles on it, i wouldnt think that the throwout bearing would have gone out by now. my noise never goes away, it starts at start up changes intensitity with the rpm, i have tried replaceing the tensioner pulley, and using belt dressing thinking that the belt was slipping and neither of those did anything, i guess the next thought is the throwout bearing. any other ideas let me know bc im kinda lost at this point.
    Fort Worth, Tx
    2002 Camaro Z28
    try switching to a full synthetic oil, it helped my clicking noise from the valves, i dont even notice it now
    Junior Member baze112's Avatar
    Pacific Northwest
    Blue
    2001 Z28 M6
    Hay, a FYI... this is what I found out.... "Trouble Shooting: After this plug install if you hear a loud ticking sound when the engine is under load then you should check your gaskets between the AIR pipe and exhaust manifold. Also, if you hear a ticking sound all the time then you probably have a loose spark plug wire boot on the spark plug." Found this at: http://www.installuniversity.com/ins...sity/index.htm I checked mine and yup, sure enough, one was loose.
    Pacific Northwest
    Blue
    2001 Z28 M6
    Hay, a FYI: Found this at http://www.installuniversity.com/ins...sity/index.htm
    under "Spark Plug and Wire Installation" Trouble Shooting: After this plug install if you hear a loud ticking sound when the engine is under load then you should check your gaskets between the AIR pipe and exhaust manifold.
    Also, if you hear a ticking sound all the time then you probably have a loose spark plug wire boot on the spark plug." Hope this helps, it did for me...
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    Quote Originally Posted by Ls1fury View Post
    DOOD!!I HAD THE SAME PROBLEM NOT TOO LONG AGO .....mine chirped when it warmed up also....who would of known it was a stupid bird churping his ass off for an escape route near the muffler
  1. chirping sound
    By kempfer99ta in forum External Engine
    Last Post: 09-13-2009, 06:05 AM
  2. Chirping Noise
    By SilentStriker07 in forum Firebird / WS6
    Last Post: 02-06-2007, 05:50 AM
  3. chirping/squeeking from exhaust
    By djsokal in forum GTO
    Last Post: 11-29-2006, 02:22 PM
  4. chirping tires into 4th?!
    By toneloc60 in forum Almost Anything Goes
    Last Post: 04-19-2006, 03:32 PM
  5. Chirping noise from belts not going away
    By chris5 in forum General Help
    Last Post: 04-10-2006, 03:40 PM
