Results 1 to 14 of 14
    Never Drink and Derive Tonik's Avatar
    '99 SS
    Serpentine Belts - Gettin Eaten.
    Any ideas on how i can figure out what is eatin' my serpentine belts? I've gone through 4 in 6-7 months.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Could be a bad tensioner or a pulley out of alignment. It could also be a damaged pulley. Does it squeek?
    in my Trans Am
    2000 Trans Am WS6
    def pullies
    Army Dude robcas47's Avatar
    Ft. Rucker Area, Lower AL
    01 TA / 06 Duc 749D
    i kind of have the same problem but i've only went through two belts so far. originally i found a crack in the belt and she squeeked so i swapped them out and used some belt treatment on the new one. now i dont know if it was the treatment or something else but after a day the squeek turned into a squeel. so i swap the belt out once more but without the belt treatment this time and didn't here anything until a couple of days later when the cold weather showed up. so now she has an annoying squeek for about 20 min and dies down a little. if the belt tensioner isn't torqued down properly could this be the problem, and if so why does it squeek?
    old timer blue02Z's Avatar
    2002 Z28
    which belt? both? i agree with prolly a tensioner poopin on ya
    01 TA / 06 Duc 749D
    yeah its the same problem on both so far
    '99 SS
    oh hell ya it squeeks.... real bad
    i did replace the tensioner a while ago... maybe i got a bum one...
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    What brand of belt are you using? I ended up replacing the tensioner,idler pulley, then the alternator(going bad anyways) and still a squeak. I replaced the gates belt I had twice, then tried a goodyear gatorback and no more squeak since then.
    01 TA / 06 Duc 749D
    i'm gonna try readjusting the tensioner, if not then i'll go with the goodyear belt. does the tensioner have a certain lubricant that must be used? because with the hood up it pretty much sounds like thats where it's coming from. i don't want to spray wd-40 in there if that will eventually hurt it. sounds like a dumb question but worth asking i guess. i asume grease since its rotational but you never know. i work on helicopters and it's funny to have to ask this about a car.
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    Quote Originally Posted by Tonik View Post
    sorry for irrvelent message..but thats a fucked up smiley
    Bragg NC
    Met. Sunset Orange
    01 SS
    When you say eating, are you talking about Breaking? Frayin on oneside or the other, If the belt is squeaking its probly time to replace although u can confirm if its the belt by using a lil "Belt dressing". Just use a little on the belt and see if it fixes the annoying squeak.
    J
    Minnesota
    83 Z28 new project
    Dont use belt dressing on a serp belt, thats a no no. I actually wrecks the belt, it was designed for v belts, theres even a warning on the can.
    01 TA / 06 Duc 749D
    Hey TONIK I went with 98Formy and a few other people's advice on the Goodyear gatorback belt and instantly the squeek was gone. i drove it around town a bit cause this was the case with the others and it came back eventualy after half a day, but then drove it again hard almost a half day later and still no squeek so i'm pretty sure this problem is solved. you might want to try it.
    '99 SS
    awesome, it'll be my next buy.
  1. Have any of you guys eaten at these pizza joints?
    Last Post: 12-14-2013, 08:19 AM
  2. This is the best thing I had ever eaten
    By FSANE in forum Almost Anything Goes
    Last Post: 06-29-2009, 07:22 PM
  3. serpentine and a/c belts
    By 0rion in forum Parts For Sale / Trade
    Last Post: 05-18-2007, 01:23 AM
  4. Rice Gets Eaten
    By IYP in forum Multimedia Section
    Last Post: 10-16-2006, 11:51 PM
