Results 1 to 1 of 1
12-05-2007, 06:40 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Installing An Improved Pontiac Cooling System - Cool Winds
Part I: The Installs
Although publishing a cooling system article as the weather starts to turn cold and blustery may seem inappropriate, it's the perfect time to reflect on the happenings of summer and plan to correct or avoid future cooling system problems in your Pontiac. By employing the latest technology, your Poncho will be prepared on the street and the track to handle anything that Mother Nature can dish up when the mercury rises. Besides, magazine publishing lead times being what they are means that in order to test in the superheated temp-eratures and oppressive humidity of August, the story will hit the newsstand in October or later.
Fortunately for the hobbyist, there are many quality choices out there to upgrade your cooling system, so we rounded up components from Meziere, Performance Rod & Custom (PRC), SPAL, and Butler Performance to outfit the '66 Tempest test car, owned by Floyd Hand of Dallas, Texas. As an entrant in the inaugural Lone Star Shootout back in '00, Floyd's A-body is a stellar performer that posts mid 11-second quarter-mile e.t.s, utilizing an iron-headed 455.
The Radiator
Floyd's cooling system was due for an upgrade, so the task of replacing the aging brass-and-copper reproduction radiator in his '66 was assigned to PRC. According to Shawn Kenney of PRC, "Our business has been built on constructing custom high-performance aluminum radiators and providing cooling system advice in order to make sure each component works well together.
"Though common Pontiac applications are available from PRC, each radiator is built to the owner's specs. We use 100 percent aluminum cores that have been furnace brazed and sourced from U.S. manufacturing facilities. No glues or epoxies are used in the cores, so common core failures due to inferior manufacturing are virtually eliminated. Based on customer feedback, the aluminum radiators we build are up to 20 percent more efficient than the copper/brass radiators they replaced." In this case, we wanted a drop-in replacement that didn't have provisions for an automatic transmission cooler. Had we opted for a transmission or oil cooler, or placement of the inlets and outlets in any position, PRC could have built it.
Electric Water Pump
To augment the radiator upgrade, an electric water pump from Meziere was sourced. Available in blue, black, red, or a polished finish from the manufacturer or Butler Performance, the pump is rated in excess of 2,500 hours of running time and includes all the necessary gaskets, seals and wiring for installation. David Butler states, "Meziere makes an excellent electric water pump for the classic Pontiac, and it is very popular with the street/strip enthusiast. In addition to reduced parasitic accessory drag by eliminating the engine-driven fan and mechanical water pump, the electric water pump and electric cooling fan combination allows racers to quickly cool down their cars between rounds at the dragstrip, leading to more consistent performance."
Electric Fan
Heath Langenfeld of SPAL related, "Since electric water pumps eliminate the factory belt-driven fan, not only is a highly efficient radiator required, but also a high-quality electric fan has to be employed to ensure adequate cooling for the engine, especially when the Pontiac is driven around town. Since the OEM car manufacturers have utilized electric fans and aluminum radiators for decades, enthusiasts can rest assured that the proper selection of components will ensure that even high-compression engines-notorious for running hot-can be accommodated."
We chose a SPAL 16-inch puller fan for our test car. As the supplier to many OEM automobile manufacturers, SPAL's puller fan incorporates a fully balanced and sealed motor that enables it to flow up to 2,360 cfm.
The fan comes with a SPAL thermostat switch, which is designed to send a signal to a relay once it reaches 185 degrees to enable the fan. After the engine cools down to 165 degrees, it signals the fan to turn off.
Alternator Relocation Kit
According to David Butler, "An alternator relocation kit is required for Pontiac owners converting to a Meziere electric water pump. The driver's side kit works on applications without power steering where the passenger side kit is for cars without air conditioning. Both kits relocate the alternator closer to the engine's pulley and virtually eliminate thrown belts at the track."
Now that you have been introduced to the parts and enlightened as to why we chose them, strap yourself in as we install the PRC aluminum radiator, SPAL 16-inch electric fan, Meziere electric water pump and a Butler Performance Alternator Relocation Kit. In Part II, the effectiveness of the new cooling system will be tested under the grueling Texas sun.
Radiator SpecificationsThe 1966 specifications are for commonly available OEM reproduction radiators. Though 4-core radiators are listed, many stock Pontiac applications used 3-core radiators. OEM-style 1964-1967 radiators used a downflow design that featured tanks located on the top and bottom of the radiator. The PRC radiator features a cross-flow design and has upper and lower fin covers.Radiator Specs'66 Standard'66 HD and A/CPRC CustomConstructionBrass/CopperBrass/CopperAluminumType FlowDownflowDownflowCrossflowCore Rows/Width(4), 1/4-inch(4), 1/4-inch(2), 1-inchCore Depth2 1/4-inches2 1/4-inches 3-inchCore Width15 1/4-inches17 1/4-inches20 1/4-inchesCore Height23 1/4-inches23 1/4-inches20 1/4-inchesOverall Width25 1/4-inches25 1/4-inches25 1/4-inchesOverall Height20 1/4-inches20 1/4-inches20 1/4-inchesWeight23-pounds26-pounds16-poundsShawn Kenney, of PRC states, "Using distilled water in radiators is very important to ensure that the minerals in tap or bottled water don't react and facilitate corrosion via electrolysis. In addition, the popular acid-based cooling system additives are destructive to aluminum.
In essence, the acid smoothes out water jacket imperfections so that bubbles don't form as readily, but in the process it attacks the aluminum."
Recommended Tools
Standard socket set
Standard wrenches
Allen wrenches
Cut-off wheel or grinding wheel
Electrical Tester
Electrical service tools (wire cutters, crimp tool, soldering iron, solder)
Recommended Parts And Supplies
Thread sealer
Fel-Pro timing cover gasket set, part number TCS-13383 (optional)
1/4-inch convoluted tubing
Electrical tape
RTV gasket maker
Conclusion
While technology has advanced significantly over the past four decades since the '66-'67 Pontiac A-bodies prowled the streets, one thing is very consistent: A cooling system that operates at peak efficiency often makes the difference between an enjoyable cruise on the town and/or success at the dragstrip, versus a frustrating day dealing with a hot-running car or, even worse, being stranded on the side of the road. HPP believes in real-world testing and the best way to do it with a cooling system is to perform it in the heat of the summer. In Part II, we will test the effectiveness of the new cooling system in August heat in Texas and explore common cooling system foibles and solutions.
Photo Gallery: Installing An Improved Pontiac Cooling System - High Performance Pontiac
More...
Cooling system (please help)
By Supersport0126 in forum External EngineReplies: 2Last Post: 03-18-2012, 07:43 AM -
Question: Cooling system
By travs98ls1 in forum Firebird / WS6Replies: 2Last Post: 07-01-2010, 07:37 PM -
Pontiac Engine Cooling System Upgrade - Keep A Coo
By Ed Blown Vert in forum GTOReplies: 0Last Post: 11-21-2008, 07:10 AM -
Pontiac Cooling System Upgrade - Cool Winds
By Ed Blown Vert in forum GTOReplies: 0Last Post: 01-15-2008, 04:30 PM -
Upgrading A C3 Corvette Cooling System - Cool It To Use It
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 09-29-2007, 06:50 AM
