Thread: Wheel/tire help
    Junior Member GungHoPopsicle's Avatar
    Nashville, TN
    '00 Camaro M6 SS #3553
    Wheel/tire help
    I'm getting new wheels and tires for the SS and I'm looking to get the widest I can get (without any sort of protrusion from the wheelwells of course). Going with 18"s all around, but with the rear wheels/tires being the widest.
    Can anyone tell me the sizes?
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    I have Corvette C6 18x10.5 on all corners... click on link in my signature.
    Also have 17x11 on all corners when racing... links also in signature.
    Eugenio_SS
    Nashville, TN
    I think my post got misunderstood. I'm not asking suggestions for wheel-type, I just need to know the dimensions because I want as wide of wheels as I can get without extending past the wheelwells. I already have the wheels picked out.
    Does 11 stick out at all for you Eugenio?
    Member 02bluez28's Avatar
    Florida
    Blue
    2002 Z-28
    Quote Originally Posted by GungHoPopsicle View Post
    But... he just told you the dimensions
    Do you mind using spacers or not? also depends on if your lowered... when you say sticking out past the wheelwell Im assuming you mean as wide as you can go without having rubbing/contact issues right?
    You also need to look into tire size not just wheel size...
    Nashville, TN
    Nah, not using spacers and yes, it's lowered. Tire size isn't so much an issue as I was basically looking for the "18x__" number. I was told 10 by someone and 11 just now in this thread, so I'm guessing 10.5 is going to be ideal, but I need to make sure the manufacturer makes them in that size.
    Florida
    Blue
    2002 Z-28
    The tire size is whats going to determine the overall width... I could be wrong, but I dont think you can get away with anything over 295's without spacers or having to roll your fenders...
    Houston, Texas
    2000 C5 Torch Red
    I have 315/35 17 Sumitomo's on the rear of my car atm and there's no issue as long as you roll the fenders. Tire really makes the difference on if it will fit. Local camaro has same wheels but I believe Kumho's and they rub the sidewall some during turns.
    Jun 2002
    Montreal, CANADA
    triple-black
    without flaring, 18x11 is pretty much the limit.
    As for spacers, it depends on the offset.
    As you can see on the links in my signature, I use wide wheels allround, and they don't stick out at all.
    17 vs 18 won't make any difference whatsoever.
    basically, as long as the offset is good, and the overall diameter of tires as well... you should be good..
    If you follow the link in my signature, you'll also see that 12" wide can be fit in both front and rear, but you need flaring in the rear... fronts are good... and we're talking 335 tires on all corners here.
    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
  1. Question: Wheel & Tire Combo
    By 98ramairguy in forum Wheels and Tires
    Last Post: 04-25-2014, 08:47 PM
  2. Wheel/Tire ?
    By Ag4ng3r in forum Wheels and Tires
    Last Post: 01-07-2012, 10:15 AM
  3. WTB GTO spare tire/wheel
    By hotrodscrap2 in forum GTO
    Last Post: 07-04-2009, 11:22 AM
  4. Wheel and tire help please
    By stefos in forum Wheels and Tires
    Last Post: 03-05-2008, 02:31 PM
  5. What do you think of this tire and wheel combo??
    By Toneloc71sr in forum Wheels and Tires
    Last Post: 04-25-2007, 06:14 PM
