Results 1 to 2 of 2
11-21-2007, 03:57 PM #1
Ignition question for window switch (tach signal)
I have installed a ZEX wet nitrous kit on my LS1 but need to program the TRACTION CONTROL WINDOW SWITCH PN #82085.
This is from the instruction manual- which system is on the LS1?
00 or the 01??
2000 Corvette.
STEP 1: TACH signal set-up
Number display B and C should be set to the chart below (Number display A is not used in this step):
0 0 = individual coil per cylinder systems where the TACH wire is connected to the coil
0 1 = coil packs that fire in pairs (waste spark systems) and the TACH wire is connected to the coil
0 2 ~ 1 2 = number of engine cylinders, from 2 to 12, where the TACH wire is connected to the tach from the engine electronic controller or distributor
Thanks for any info-
Chris
11-23-2007, 03:08 PM #2
FYI-
Figured it out today by trial and error, it is the 00 setting.
Fired the nitrous for the first time today--
SWEET...................
Nos window switch question
By GUSHER in forum NitrousReplies: 3Last Post: 02-28-2012, 09:32 AM -
ignition switch question
By leon phelps in forum Classic MuscleReplies: 2Last Post: 01-15-2012, 09:51 AM -
Question: 98' tach signal.
By yellowv in forum Computer & TuningReplies: 4Last Post: 09-23-2008, 12:20 PM -
Tach Signal help
By Granatelli in forum General HelpReplies: 3Last Post: 07-17-2008, 01:18 PM -
Rpm Window Switch Question
By GUSHER in forum NitrousReplies: 1Last Post: 09-02-2007, 01:49 PM
